Etched brass and c/a
  • David Lovell
    • 2186
    #16
    I meant to add my thoughts(or as usual poke my five eggs in) some time ago so just as you all thought it was safe......a good few years back now I bought some glue loopers at Telford apart from the smallest size thought they had made me part with my money for nothing ,then at one of the Poole Vikings model shows got my hands on a needle put in a piece of dowel with the eye cut in half couldn't get on much sense ,so have mostly just used blunt pointy scaple blades I suppose just developing my own technique.
    Some where on here a while age was a discussion about canopy glue ,can't remember who but something like canopy zap? was recommended ,also noted that it was good for small photo etch parts so a quick surf on flea Bay produced it at various prices found one with these I think there called glue droppers/spotters price was more with free postage than the cheaper one but that had postage making it the same price
    This is the best since soft toilet roll ,carefully dip/touch the small ball end in the ca then touch where the etch goes and it deposits a tiny drop of CA just place etch on top dead easy. To clean the tip you can pick it off or show it a fag lighter/Gas cooker. Piece to small for tweezers then I use one of thoes pencils with the white waxy ends ,also a cocktail stick with a bit of saliva works. The canopy glue has yet to be used says on the bottle it takes three hours to fully set cant hang about waiting for that but if a wingy thing does fall from the stash I'm in. Dave
    • Andy T
      • Apr 2021
      • 3239
      #17
      Wow Dave, I have a set of those that were sold as sculpting ball tools but have hardly been used as such. I've just started a kit that has some etch parts so will try giving them a new lease of life as glue applicators!
      • David Lovell
        • 2186
        #18
        Andy practice on a bit of scrap plastic as I said gently touch /dip in the ca then touch where etch goes and a nice little drop of ca will be left there once you've got your eye in you can get it down to pin head size. Hope it works for you it dont half make life easier. I use rocket ca the one with the blue lable gives you 10-20 seconds ages to push and pull the etch about. Dave
        • stillp
          • 8087
          • Pete
          • Rugby
          #19
          They look like those nail art 'dotting tools' that Tony uses.
          • Miko
            • Feb 2024
            • 582
            #20
            Useful, my sword Lighting has etch, it seems tiny amounts of CA is the key.
            . . . and remarkable eyesight!
            Miko (learning stuff today)
            • David Lovell
              • 2186
              #21
              Just re-read through all intresting stuff ,struggling with tiny parts picking up /positioning them have look on flea Bay stick in rinestone pickers ,I use one of the white pencils even for small plastic parts. Dave
              • JR
                • May 2015
                • 18273
                #22
                Glad that works for you Dave, I have two pencils, they used to work but now just don't pick anything up ?
                • stillp
                  • 8087
                  • Pete
                  • Rugby
                  #23
                  A wash in warm water should help John. I have the opposite problem - I find them too sticky!
                  • JR
                    • May 2015
                    • 18273
                    #24
                    Thanks Pete, I'll do that . Probably have a coating of dried CA on them.
                    Oh wish mine were like that :thumb2:
                    • David Lovell
                      • 2186
                      #25
                      Hello buddy really small photo etch pieces some spit on the end of a tooth pic works as well as all the gizmos mentioned here.
                      • Scratchbuilder
                        • Jul 2022
                        • 2689
                        #26
                        Originally posted by Jim R
                        Very useful and very well explained. I assume the CA used is the thin, rapid variety.
                        I suppose you have to work pretty quickly so that the CA doesn't harden before you get to it.
                        I like the idea of using an old blade as a CA applicator.
                        Sorry Jim,
                        I have just seen your question/comment.
                        The c/a stays wet long enough for you to complete the task of clearing the excess, and the pin will drag enough off to clean up the joint.
                        Mike.
                          • 18891
                          as does a minuscule amount of blue tackā€¦..
                            • 15655
                            Thanks Mike
                            Very true. I have found that works a treat.
