Weathering using oil paints and applying rust
  • jspitza
    • Jul 2007
    • 586
    Hello all:
    I've had the honor of being asked by a few here to demonstrate how I weather parts using oil paints and then create rust. I'll start by listing the items used in this tutorial and then add to the thread as pictures become available. I'll post the first and last pictures of the weathered piece now.
    1. A piece of something from the Airfix Canberra kit (bomb bay wall)
    2. Testors Modelmaster Panzer Dunkelgelb 1943 enamel
    3. Weber Turpinoid (for thinning the oil paint)
    4. Pollyscale Clear flat acrylic
    5. Various brands (dick blick student grade, something fancy but was on sale brand and Windsor cheap, we can't sell this stuff cause its crap line) Oil paints. My oil paint colors, six in all used were burnt sienna, raw umber, titanium white, Yellow Ochre, Ivory Black and Van Dyke brown
    6. Tamiya neutral grey acrylic
    7. Tamiya flat black acrylic
    8. Testors Modelmaster chrome silver enamel
    9. Various pastel chalks in four colors-brown, black, bright reddish something and an orangey tan thing. Please refer to the photos as your guess is as good as mine.
    10.Micro krystal klear
    11. A #2 lead or graphite pencil
    12 Testors Modelmaster flat lacquer
    13. A flat shader or chisel brush-say an inch wide and one small pointed brush
    14. A note pad to keep track of all of this and your progress!
    [ATTACH]18155.IPB[/ATTACH]
    [ATTACH]18156.IPB[/ATTACH]
    [ATTACH]18157.IPB[/ATTACH]
    That's a great looking rust-job you did on that piece, jspitza!
    Looking forward to seeing the process.
    Frank
    • jspitza
      • Jul 2007
      • 586
      Ok, lets start!
      I've chosen Testors Modelmaster Panzer Dunkelgelb 1943, airbrushed the part and let sit overnight. Also, I always use the recommended manufactures thinner.
      [ATTACH]18158.IPB[/ATTACH]
      [ATTACH]18159.IPB[/ATTACH]
      • jspitza
        • Jul 2007
        • 586
        Good morning!
        You did let that part dry overnight, actually 24 hours BEFORE putting your paws on it, right? Good! Lets apply a coat of Pollyscale clear flat acrylic with a nice brush and let dry for a couple of hours. I choose 4 hours just to play it safe. This is a great time to tell your wife when you will finish all the chores since blowing them off to read this!:tulip:
        [ATTACH]18160.IPB[/ATTACH]
        • jspitza
          • Jul 2007
          • 586
          Everything ok now? Laundry folded, floors mopped, dinner cooked? Good!
          Lets take out our oil paints and choose the colors. I used all six and think that all of these help create more natural staining because of color blending. I only bought the cheapest paint possible and I used these colors:
          burnt sienna, raw umber, titanium white, yellow Ochre, Ivory Black and Van Dyke brown
          [ATTACH]18161.IPB[/ATTACH]
          • jspitza
            • Jul 2007
            • 586
            Now lets take our Turpenoid or other oil paint thinner, paint brush and part to the table. Lets use a toothpick and apply a dab of each color stating at the top of the part.
            [ATTACH]18162.IPB[/ATTACH]
            [ATTACH]18163.IPB[/ATTACH]
            • jspitza
              • Jul 2007
              • 586
              Lets take the clean brush and dip into the thinner. Start pulling the brush down onto each color, wipe clean onto a towel and dip into the thinner. Repeat until there looks like nothing is left! Please look carefully at the photos and you'll notice that it will take at least three to four passes before the colors blend and finally appear removed. Now look at the last photo and you'll see very faint traces of colors that flowed into the raised pieces. After the painting, I used light air blown from my airbrush onto the part to speed up the drying process. Let this dry overnight-say 8 hours or so. Its oil paint so If this was a bigger part or complete model, I'd give it almost a full week for the oil to evaporate!
              [ATTACH]18164.IPB[/ATTACH]
              [ATTACH]18165.IPB[/ATTACH]
              [ATTACH]18166.IPB[/ATTACH]
              [ATTACH]18167.IPB[/ATTACH]
              • jspitza
                • Jul 2007
                • 586
                Good morning! You DID let this part dry overnight-at least 8 hours or so BEFORE putting your paws on it, right? Good! Look closely at the picture and your part. Notice the very subtle change in appearance.
                :yes:
                [ATTACH]18171.IPB[/ATTACH]
                • jspitza
                  • Jul 2007
                  • 586
                  OK, lets start the next step!
                  I make a mixture of 91 percent Isopropyl alcohol, Tamiya (XF-1) flat black paint and distilled water to use as a wash. Just put a dab of the paint into the water, alcohol mix. The mix should look like blackish water. Take your paint brush, dip into the wash mix and brush everywhere. It should flow freely, like water. Next, take a cotton bud to selectively roll over the part, dabbing gently into the wash mix that pools up and stops flowing. Set the part aside to dry which should not take more than a few minutes. If you rub too hard, you'll rub down into the Pollyscale clear coat.
                  Good night, I'm beat!
                  [ATTACH]18172.IPB[/ATTACH]
                  [ATTACH]18173.IPB[/ATTACH]
                  [ATTACH]18174.IPB[/ATTACH]
                  [ATTACH]18175.IPB[/ATTACH]
                  • jspitza
                    • Jul 2007
                    • 586
                    Originally posted by \
                    That's a great looking rust-job you did on that piece, jspitza!Looking forward to seeing the process.
                    Frank
                    Thanks Frank!!!!!
                    Take care, Jeff
                    • jspitza
                      • Jul 2007
                      • 586
                      Hello all. Please accept my most sincere apologies for stepping out for awhile. Many problems sorted out this summer! I'm glad to once again participate and share with this wonderful group! I shall continue right from the point of stopping:
                      After our wash has dried, we will need to make a solution of water and Krystal Klear-but not too thick:
                      [ATTACH]19331.IPB[/ATTACH]
                      • jspitza
                        • Jul 2007
                        • 586
                        Now, I've shaved off some of my favorite chalks-black, browns and reds seem to work the best. Did I mention orange as well:yes:
                        [ATTACH]19332.IPB[/ATTACH]
                        [ATTACH]19333.IPB[/ATTACH]
                        • jspitza
                          • Jul 2007
                          • 586
                          Ok, now is the really fun part! Actually, it is!
                          Place your tip of the brush in the weakened solution of Krystal Klear.
                          [ATTACH]19334.IPB[/ATTACH]
                          [ATTACH]19335.IPB[/ATTACH]
                          • jspitza
                            • Jul 2007
                            • 586
                            And then take a few of your chalks and spread the powder onto the palette.
                            Then Dip your brush tip into different colors and just lightly dab them onto the parts brake lines, crevices, ect. Remember, YOU control the nature effect and by this I mean how rusty things can get is unlimited! The Krystal klear will act as a glue so you can mix and match various shades and thickness to your liking. I like to make it caky (is that a word? and leave it be without painting it and allowing the texture to build up. The glue will hold it in place as will a final coat of clear varnish or final coat.
                            [ATTACH]19336.IPB[/ATTACH]
                            [ATTACH]19337.IPB[/ATTACH]
                            • jspitza
                              • Jul 2007
                              • 586
                              After do this a few times, you'll get the hang of it and then rock on!
                              The panel will now look like this:
                              [ATTACH]19338.IPB[/ATTACH]
