Tips for the small scale modeller.
  • wonwinglo
    • Apr 2004
    • 5410
    We all remember our grass roots and the very first models that we built,in many cases these would be kits of scale subjects produced by such companies as Keil Kraft,Veron,Skyleader,Comet,Keelbuild,Guillows etc etc.In many cases these kits would include inferior balsa sometimes the density of floorboards and would split under the balsa knife and flustratingly glued back together again !
    Many of these designs were built on a keel with the formers glued onto them,then the slots for the stringers would be cut and an immensely strong structure would evolve,note how I say the stringer slots are cut after assembly and not cut out before as the kits incorrectly state ? the reason for this is the impossibility of knowing exactly where those slots actually appear,there is nothing worse than a stringer out of line which looks as if it had been on the Guinness ! with the advent of modern adhesives these models have been made much easier to build,no more fiddly waiting for balsa cement to dry as that critical part wanders out of line,a quick zap and the jobs done.
    Before we even start our kit lets take a very critical look at how we can save valuable weight,most modern kits are now die cut,or more likely die-crushed if the cutting dies are worn out and have seen better days,in the later case it is best to consign these sheets to the trash bin and start again,to do this take the sheets before trashing to your local friendly print shop,ask them to print the sheets on sticky back paper,then all that you need to do is go home and place the sheets onto fresh lightweight balsa,by cutting the parts out the tacky film holds the wood together,then it is easily peeled off after cutting out.If the wood is ok and of reasonable weight ( a small set of digital scales is something that I need and suggest) then we can take a sanding block and remove a few thou of wood by vigorous sanding outside on a flat surface,by sanding on the reverse of the die cutting process the parts will just drop out from the sheets nice and cleanly,place these carefully into plastic food trays or something similar,nothing worse than loosing a vital part at this stage.Remember not to cut any slots we will do this much later with a warding file directly in situ on the model just prior to fitting the stringers,to avoid damage hold the former with a small wooden block with a slot cut into it,this stops the former flexing as you use the file.
    That will do for now and I hope that these few words will give renewed interest in these small models that with care and attention can be made into little gems of a flying model,next time I will deal with other aspects of the build and also culminate with ways of even fitting micro radio gear into these models,yes it is now a practical proposition to do so,and the sight of a 15 to 18 inch span model up high in the sky and being flown from a cabbage patch is something else to really enjoy !
    Barry
    As I made my intro a few days ago, and am interested in these types, thanks for the post you made. I read it with interest; it's the sort of stuff I think I need.
    What's the view amongst 'purists', if there are any, about factory pre-cut parts? Is it not the 'done thing' to simply press out the parts and stick 'em together? Is there more kudos if you cut your own parts?
    I'm not looking for kudos, well, not too much! I just wonder what value there is in 'simply' pressing out the parts, rather like an airfix kit or whatever, rather than slavishly rigging something up and carving for a few nights?
    I am looking forward to cutting my own wing ribs set in a jig of some kind - maybe even some that taper to the wing tip. I think I saw this somewhere -I believe the ribs were held together while their shape was carved to the pre-determined shape.
    Tim
    • wonwinglo
      • Apr 2004
      • 5410
      Die cutting is now a thing of the past,with the advent of laser cutting clean as a whistle,no problems here because you still have to build these models with accuracy and care,just open the kit and enjoy the contents,a bit of prefab will not harm Tim,I have no hang ups in that direction,some of the changes like better decals,contest grade balsa are now the norm in the many cottage industry American kits.
      Glad you liked the first tute on these little models,watch this space.
      • wonwinglo
        • Apr 2004
        • 5410
        BarryAs I made my intro a few days ago, and am interested in these types, thanks for the post you made. I read it with interest; it's the sort of stuff I think I need.
        Tim
        *** Tim,go to here http://scale-models.co.uk/showthread.php?t=735 where we have covered this in detail in a tutorial.
