unconventional modelling materials list
    I do love this thread , sorry if this has already been mentioned before but I mould tin foil into a small artists paint pallet when using lots of colours , when finnished I just bin the foil , when I was painting and decorating I even used this method with paint trays - works a treat
    Richy
      hey here goes. sorry for the poor quality. the fact they are cream makes them anightmare to photograph under atrificial light... im alos a pants photographer but hey. you should get arough idea. the results are rendom which is part of what makes them so good. the other thing that works well is tree bark btw...
      anyhow milliput rocks (not yet painted)
      (the 2nd picture is only there to illustrate the size that base is about 2 inches across.
      you can make the rocks much smaller or bigger depending on what flavour your looking for. works good for rubble too
      hope it helps any advice on how to take less poo pics would be good
        Nice idea for slate nistrum like it.
        scott
          im just sorry the pictures dont illustrate it very well. the best thing to do is try it for yourself
            One from Aussie-land. Run thin thread over a piece of beeswax to smooth out fine fibers and give the thread a polished look.
              Nice one richo - thread is almost always too "hairy" for our usem that solves the problem
              • tr1ckey66
                • Mar 2009
                • 3592
                #82
                Ooooo, this thread is good!
                Here's a tip I swear I use on every model. A Precision Super Glue Applicator that anyone can make for next to nothing - and what's more it does a better job than most bought stuff.
                Take a piece of dowel around 6 inches in length, stick a pin in one end and then cut the end off the pin with some wire cutters (protect your eyes when doing this). Now whittle the end of the dowel a little bit at the pin end (this will enable the tool to reach more difficult areas on a model). You now have your CA glue applicator.
                [ATTACH]15506.vB[/ATTACH]
                To use:
                1. Decant a small amount of CA into an old milk carton top.
                [ATTACH]15505.vB[/ATTACH]
                2. Dip the 'tool' in the CA and 'pick up' a tiny amount of glue to put exactly where you want it - simple!
                [ATTACH]15507.vB[/ATTACH]
                Hope this adds to the great suggestions so far.
                Paul
                [ATTACH]23800.IPB[/ATTACH]
                [ATTACH]23801.IPB[/ATTACH]
                [ATTACH]23802.IPB[/ATTACH]
                  Nice one Paul, not only a great tip for a DIY tool but pictures showing it as well. Great presentation of a simple but great idea. I am off to make one now.
                    A good and useful tip, i'll add though to possibly make things easier for Fenlander.
                    I use pretty much the same system but with an old needle chucked in my pin vice, (I got a pack of two and one gets used for drilling the other pretty much holds the needle all the time, I also use it (it gets cleaned of CA after every use), for scribing too.
                      To expand on this one slightly, I've seen elsewhere an idea where instead of a pin, it's a needle installed point-first into the dowel. then the eye is cut across, halfway up so it leaves a fork shape. This can then be used to pick up and apply thin CA or liquid cement.
                      HTH
                      Stuart
                      • tr1ckey66
                        • Mar 2009
                        • 3592
                        #86
                        Backonthecase, I've been thinking of how to make a CA accelerator tool - that sounds perfect. I may paint one of the 2 tools red or something just to tell them apart. Cool!
                        Paul
                        • Gern
                          • 9212
                          #87
                          Hi folks,
                          Tony suggested I put a couple of the items I used for my GB on here for quick reference so here goes:
                          Dried herbs (the sort you buy already shredded in small bottles from people like Schwartz) make good leaves - use spray adhesive and just sprinkle away.
                          Baking powder makes good snow (I've heard of folks also using talcum powder). I use an old pepper pot as a shaker to get a more natural appearance. You can also use the pepper pot to add pastels etc for really heavy weathering effects.
                          Scouring pads can be torn up to provide small shrubs and bushes. They're really effective when covered with the herbs!
                          Someone's already mentioned that cheap jewellery is a source of small beads. But you also get chain, wire, and hooks and eyes (ever lost or broke a DF loop on a 'plane?). Some have coloured clear plastic which can be used for wingtip lights and silver sequins for the inside of headlights etc.
                          Large paper clips provide good stiff wire for reinforcing joins etc. I also use them inside hollow undercarriage legs. (I build 'planes mostly in 1/32 and 1/24 which are heavy - especially when you have to add weights for 'tail sitters'. Adding the reinforcement to the undercarriage seems like a good idea to me - even though I've not had any break as yet).
                          Gern
                          • Gern
                            • 9212
                            #88
                            Back again!
                            One I had to do yesterday. I lost a small grab handle to the carpet monster. I took another one the same size from the kit and placed it over one of the jaws of my fine nose pliers. I slid it up the jaw until it wedged where the jaw was the same width and marked the spot with a pencil. Guess where I put the bit of wire I was using to make the replacement before I bent it to shape!
                            Gern
                              I found something interesting, while destroying random stuff.
                              Take one of these.
                              Cut off one end
                              Open it up untill you get some chrome strips. They're harder than BMF and of course a bit thicker, but I think people could find uses. Oh yeah and the other side of these look kind of like brushed aluminium.
                              But wait!
                              There is one last strip of metal bundled up between two layers of plastic.
                              It's shorter and isn't chrome. What you get depends on your luck I got an aluminium like strip and one that looks like copper.
                              Have fun!
                              • Centurion3RTR
                                • Jan 2009
                                • 2093
                                #90
                                Super glue casting on tanks.
                                All you need is a cheap bottle of super glue, (the runny stuff from the pound shop) and something as a tool. I just used a piece of thick wire (electric cooker wire). Right, the casting. Put some super glue on a piece of paper, dip your wire into the glue then spread it on the part you're "casting". Move the wire around until the glue just and i mean just starts to go off then leave it, because it dries quick the job is done in minutes.
                                Have fun, John
                                [ATTACH]27704.IPB[/ATTACH]
                                [ATTACH]27705.IPB[/ATTACH]
                                [ATTACH]27706.IPB[/ATTACH]
                                [ATTACH]27707.IPB[/ATTACH]
