unconventional modelling materials list
  • PJP
    • Feb 2010
    • 192
    #106
    Continuing the contact lens theme, the little plastic cups which hold daily disposable contact lenses make perfect paint mixing pots for small quantities. Having used the lenses first, you will probably then be able to see what you are doing...
      For a cheap Model clamp - some coat hangers and in particular the ones for Womans' (is there any other?) dresses, have small clothes peg attachments. These are padded and are held together by a small metal sheet, are flexible enough to hold plastic - together e.g. wings etc.
        Hi this could be of interest i used to do a bit of games workshop modelling when i was a kid and i found a good plant for trees bushes was heather so if your out walking in the hills remember to have a look you want to cut the heather close to the base where you will find the twiggy wood (i used to dry it out so the greenery is lost). Well might not suit everyone but worth a look and free.
          Humble Thistle
          Hi all,
          Some of you may have seen my other thread but now that I have revealed what i used for creating long grass/reeds I shall now share on here.
          I was walking the other day and spotted that the heads on some thistle remarkably looked like an brush and on closer inspection it got me thinking if I could use it as long grass as I had been looking for a cheap alternative for my long lasting dio I am still working on I started for the Normandy GB.
          These are some shots of how it looks and what to look for when out walking. I imagine there are many more seeds like this that could be used in similar ways.
          For the amount used in the picture this was all from one head and still more to go, so you wont need many if ever you get some, leaving some to propagate for next time! Would hate to think that all of a sudden there where report that there was a sudden decline in thistle species with scientists not sure why LOL!
          Happy hunting
          Rich
          P.S Just be sure if you are picking wild flowers your not lucky enough to find a protected species, so think before you pick!
          [ATTACH]37947.IPB[/ATTACH]
          [ATTACH]37948.IPB[/ATTACH]
          [ATTACH]37949.IPB[/ATTACH]
            cannot claim credit for this one as i read it in a magazine but if any one needs 1/35 scale leaves to scatter on a dio then you can get the seed pod of a birch tree and l leave it to dry out and go brown. then when dried you can just rub it down with your finger and you have hundreds of tiny looking leaves. they can be left as is for dead leaves and a few painted in different colours for varying states of deadness.i have a pot full already but have not used them yet.
            • yak face
              • Jun 2009
              • 13841
              • Tony
              #111
              Quick ,Cheap airbrush holder
              Heres a quick and very cheap way to make a holder for your airbrush when you need to put it down when theres still paint in the cup.( This probably only works on standard layout airbrushes so maybe wouldnt be any good for the pistol trigger types) Get yourself a plastic nozzle , the type you get with a tube of silicone or painters mate etc.( sometimes shops will give these free !! Bonus!) Cut the threaded end off at a point just larger than the end of your airbrush and cut a 45 degree angle on the narrow end. Then get a screw and put it inside and screw it to wherever you want ,the bench, the wall ,even a heavy enough block of wood. The airbrush should sit in at just the right angle so that it stays there and the cup should be just about level. Sounds Complicated? it really isnt , heres a pictorial guide , cheers tonylane:
              [ATTACH]38209.IPB[/ATTACH]
              [ATTACH]38210.IPB[/ATTACH]
              [ATTACH]38211.IPB[/ATTACH]
              [ATTACH]38212.IPB[/ATTACH]
              [ATTACH]38213.IPB[/ATTACH]
              [ATTACH]38214.IPB[/ATTACH]
              [ATTACH]38215.IPB[/ATTACH]
                I have one,
                Another method of making dirt, snow, concrete, stone,
                is plaster of paris.
                Mix up the plaster to a pancake batter, add acrylic paint of your choosing, and spread on diorama. If sand and some tan paint is mixed in, it makes great sand for desert dioramas.
                Does anybody know of a good way to make Zimmerit? i have tried with putty, but it always was very hard to work with. I was thinking perhaps of white glue mixed with a fine powder of sorts. Any ideas?
                Hope this helps.
                -Chris.
                  Chris, the best bet for zimmerit is milliput fine, rolled really thin then stuck to the surface.
                  HTH
                  Stuart
                    actually, in the meanwhile i have discovered that acrylic craft paint + white glue + flour is great, applied in the same manner, only much easier to work with.
                      As a follow on to posts 82-86 - Something I discovered the other day was a use for those empty Revell /Humbrol liquid glue (needle) containers - Cleaned out they make great applicators for CA Adhesive. Put a blob of CA on a piece of scrap plastic and dip the tip of the needle into this, squeezing the container a little first . just enough to suck up a little CA into the needle . You can then use like a hypo to transfer the CA to exactly where it's needed, by gently squeezing the container again to push the CA out .... Make sure you empty the needle when finished, and you can always clean a clogged needle of any dried CA with a length of wire ... (I use a short length of plain guitar string which is quite rigid.)
                      Tony R
                        Drinking straws for moving paint from one or two jars to a third mixing container dip and place finger tightly over straw end few drips easy decanting for air brush mixing etc .
                          Use tops off Pringles boxes for mixing painting and thinning paint prior to air brushing or brush work .
                            Dried Acer ( Maple) leaves make great ground cover as it retains the colour even when fully dried . Crush in paper bag to size required and scatter on diorama . Instant Autumn ground cover !
                            • yak face
                              • Jun 2009
                              • 13841
                              • Tony
                              #119
                              Ok peeps , heres one for all you choccy lovers! When using vallejo paints for brushing in small amounts ,the eye dropper bottle is a bit of a pain as you have to squeeze a bit of paint out onto something to brush from- what you could do with is a cheap disposable pallette , so how about this .Step 1- Get yourself to the poundshop and purchase a box of these[ATTACH]39822.vB[/ATTACH] Step 2- Eat all the choccies (in one sitting if you want , I did !!!!)[ATTACH]39823.vB[/ATTACH] Step 3- you are now left with 15 half round single use palettes ,perfect for a few drops of your chosen vallejo paints[ATTACH]39824.vB[/ATTACH] No more little splodges of paint on the cutting mat for me! ( health and safety warning: if you are allergic to nuts then get someone else to eat them for you!!LOL) cheers tony
                              [ATTACH]43615.IPB[/ATTACH]
                              [ATTACH]43616.IPB[/ATTACH]
                              [ATTACH]43617.IPB[/ATTACH]
                                Brilliant, a win-win solution :terrific:
