If you are allergic to cyno like most of us then why not use active aliphaetic ? it is easy to make your own,just place a quantity of full strength aliphatic into a small bottle,add water so that the adhesive just flows like milk,allow to settle for 15 minutes to get rid of bubbles,take a large syringe,put the home brew into the syringe,replace the rubber bung/plunger,hey presto ! enough adhesive to keep you going for a month.
Build a wing,set up the ribs etc,flood the joints with your applicator,allow 24 hours to dry,lift wing,then sand up.
