Repairing a Glass Fibre Fuselage Soarer
  • Glider Guider
    • Oct 2004
    • 88
    At the Nats this year I bought a Pat Teakle PIK 20 4m soarer complete with airbrakes and five servos for the princely sum of £30 from the Sunday ‘table top’ sale. Just the airbrakes and servos would fetch more than that on Ebay so there must be a catch somewhere I hear you cry especially as a similar one has just fetched £240 on Ebay. There is a catch, unfortunately it has had a heavy ‘one point landing’ which had detached the tail and caused cracking below the cockpit as well as in one wing and the tailplane, but as I paid less than nothing for it I’m not complaining.
    I have just reattached the tail and thought it might be of interest to someone and hopefully generate some discussion so here goes.
    As you can see below the tail was well broken off and it wasn’t a nice clean break.
    [ATTACH]7285.IPB[/ATTACH]
    [IMG]/monthly_2004_12/57272b6cecbe7_640x480PB300013.jpg.8eb808415469b485 7c5f2e9431010a92.jpg[/IMG]
    [ATTACH]11980.IPB[/ATTACH]
    [ATTACH]12580.IPB[/ATTACH]
  • Glider Guider
    • Oct 2004
    • 88
    I decided to repair it as described at http://www.windandwavemodels.com/Repair.html by fabricating a glass fibre splint that is inserted into the two halves of the fuselage. Making the splint 6” long was convenient as I had some 6” wide wing joining glass and this gave 2” into undamaged fuselage each side of the damaged area which I thought would be sufficient to give a strong repair.
    The first job was to make a plug to wrap the splint around as using the fuselage itself was not practical due to the extent of the damage. This was made from four 8” lengths of 1” square balsa glued together which was then planed down to the outside diameter of the fuselage as measured at the forward extent of the splint. By using the outside diameter there would be an overlap of the splint which would press against the fuselage both holding the splint in place and giving a better joint. The plug was then tapered over 6” of its length again to the outside diameter of the rear fuselage leaving 2” to be held in the vice as illustrated below.
    [ATTACH]7288.IPB[/ATTACH]
    [ATTACH]7287.IPB[/ATTACH]
    [ATTACH]7286.IPB[/ATTACH]
    [IMG]/monthly_2004_12/57272b6cefa92_640x480PB300019.jpg.27a897301b5a2f18 04c349676baaa7fc.jpg[/IMG]
    [IMG]/monthly_2004_12/57272b6ceec6f_640x480PB300018.jpg.1a5595e9cbab0ad9 8f7e3bc9b954c409.jpg[/IMG]
    [IMG]/monthly_2004_12/57272b6cedd23_640x480PB300017.jpg.f85b70a9cb615669 f8a4132f4a63aa0b.jpg[/IMG]
    [ATTACH]11981.IPB[/ATTACH]
    [ATTACH]11982.IPB[/ATTACH]
    [ATTACH]11983.IPB[/ATTACH]
    [ATTACH]12581.IPB[/ATTACH]
    [ATTACH]12582.IPB[/ATTACH]
    [ATTACH]12583.IPB[/ATTACH]
    • Glider Guider
      • Oct 2004
      • 88
      The splint was made from three layers of glass and epoxy resin sandwiched between acetate sheets. This sandwich (including the acetate sheets) was then compressed with a wallpaper roller to expel any trapped air and then wrapped around the plug and held in place with sticky tape. After 24 hour to allow the resin to fully cure the splint was cut from the plug by using a razor saw along its length.
      I wouldn’t recommend using polyester resin, although it is cheaper and it goes off faster (20 minutes against 20 hours) the result is more brittle than epoxy resin and you also want plenty of time to get things right before it goes off.
      Finally remove the acetate sheets and give the splint a rub with glass or emery paper to roughen the beautifully smooth glass like finish of the splint. Although it looks nice it is not a good surface for the epoxy to adhere to when the splint is fitted into the fuselage.
      [ATTACH]7291.IPB[/ATTACH]
      [ATTACH]7290.IPB[/ATTACH]
      [ATTACH]7289.IPB[/ATTACH]
      [IMG]/monthly_2004_12/640x480PC010024.jpg.015292fff80c3f4e075e92cef78114 58.jpg[/IMG]
      [IMG]/monthly_2004_12/57272b6cf18cf_640x480PC010023.jpg.fda741f9bb8acd0a 202919da0a0ddf9c.jpg[/IMG]
      [IMG]/monthly_2004_12/57272b6cf08e6_640x4880PB300021.jpg.dde2b4513a4a158 859728f9adadd6baf.jpg[/IMG]
      [ATTACH]11984.IPB[/ATTACH]
      [ATTACH]11985.IPB[/ATTACH]
      [ATTACH]11986.IPB[/ATTACH]
      [ATTACH]12584.IPB[/ATTACH]
      [ATTACH]12585.IPB[/ATTACH]
      [ATTACH]12586.IPB[/ATTACH]
      • Glider Guider
        • Oct 2004
        • 88
        The tail is quite heavy so there was no chance of just inserting the splint, binding it up and expecting the tail to be in the right position when the epoxy had cured so I built up a jig on a fuselage building board which is conveniently inscribed with squares which assist alignment. This held the fuselage still while I adjusted the tail position by using wooden wedges. Once alignment was correct the position of the wedges was marked.
        [ATTACH]7292.IPB[/ATTACH]
        [IMG]/monthly_2004_12/57272b6cf352e_640x480PC030025.jpg.d53a7ba8bfb313ad 0e485b8204aebf34.jpg[/IMG]
        [ATTACH]11987.IPB[/ATTACH]
        [ATTACH]12587.IPB[/ATTACH]
        • Glider Guider
          • Oct 2004
          • 88
          The splint and the inside of the fuselage were now given a liberal coating of epoxy resin and the repair was made; all being held firm by the jig. At this point I decided to bind the repair in acetate sheet and I also made a simple gauge to check the fin was at right angles to the wing-joining rod with the aid of the Mk 1 eyeball.
          [ATTACH]7294.IPB[/ATTACH]
          [ATTACH]7293.IPB[/ATTACH]
          [IMG]/monthly_2004_12/57272b6d010ad_640x480PC030027.jpg.df60e59cd772107e a9aa5792c76c4b0f.jpg[/IMG]
          [IMG]/monthly_2004_12/57272b6d001d4_640x480PC030026.jpg.b17430ae79272248 3c81e0b81765c6b0.jpg[/IMG]
          [ATTACH]11988.IPB[/ATTACH]
          [ATTACH]11989.IPB[/ATTACH]
          [ATTACH]12588.IPB[/ATTACH]
          [ATTACH]12589.IPB[/ATTACH]
          • Glider Guider
            • Oct 2004
            • 88
            I was concerned that the epoxy resin was very thin compared to resins I’ve used in the past and quite a lot of resin was dripping from the repair (one of the reasons I bound it) and running inside the fuselage; but nothing to be done until it had fully cured when the fuselage could be removed from the jig and the resulting strength of the repair judged.
            I allowed a full 48 hours for it to cure and removed the fuselage from the jig. Although the strength of the joint seemed satisfactory I decided to reinforce it with carbon fibre tows. The joint was filled with two part filler, sanded down and a number of grooves were ground through the gelcoat until you could see the glass fibre. The tows were glued in place with cyano (superglue).
            [ATTACH]7295.IPB[/ATTACH]
            [IMG]/monthly_2004_12/57272b6d01ebd_640x480P1010035.jpg.ef1ae17520f1b2d1 b895f9e154a82c85.jpg[/IMG]
            [ATTACH]11990.IPB[/ATTACH]
            [ATTACH]12590.IPB[/ATTACH]
            • Glider Guider
              • Oct 2004
              • 88
              This really stiffed up the joint and a final application of filler and a rub with 240 ‘wet and dry’ used wet gave the result shown below which is almost ready for spraying.
              [ATTACH]7296.IPB[/ATTACH]
              [IMG]/monthly_2004_12/57272b6d02f80_640x480P1010037.jpg.ba8884ba9ab5f383 66bedf91594094b2.jpg[/IMG]
              [ATTACH]11991.IPB[/ATTACH]
              [ATTACH]12591.IPB[/ATTACH]
              • Glider Guider
                • Oct 2004
                • 88
                Health Warning!!!
                I couldn't finish without a few health warnings about procedures used in this repair.
                When sanding or sawing glass fibre always wear a respirator.
                For a while now I have had what appears to be quite bad hayfever occasionally but this didn’t seem to relate to the current pollen levels and I wondered if it was caused by cyano glue fumes. The afternoon after gluing the carbon tows the question was answered when my nose blocked up totally and started pouring also my eyes felt sore and now 48 hours later I am still suffering but things are improving slowly. On the bottle it has an irritant warning and says not to breath the fumes but I’ve used cyano for years with no problems and it’s only recently that I’ve become allergic to it.
                I’m now on the look out for a respirator that guards against fumes, Screwfix have one at £2.50 or so but the P&P on one item makes it more like £7.50, and I will wear a set of goggles as well. Other people who have had this problem have apparently used a fan to blow the fumes away before they reach the face with good effect and also the low odour cyano causes less problems - but after this bout I’m taking no chances in future, it will be respirator, goggles and a fan.
                Has anyone else had this problem, if so how have you got over it?
                  :clap3: oster_ke :goodpost:
                  • wonwinglo
                    • Apr 2004
                    • 5410
                    Very informative Dave,there is a lot of good user information contained in these postings,the warnings about these cyno fumes are very real as I have heard many people say that sometimes after years of use the user can suffer,after suffering myself from a bad skin problem on my hands these past few years now I take much greater care with these products,in this case tests showed that epoxy resin was one of the irritants but after years of usung glo-fuel,dopes and various adhesives these cannot be ruled out,herbal treatment has sorted out the skin but it is a long expensive process.
                    Without fear mongering it is a well known fact that the constituents of glo-fuel can cause senile dementia,so please take care and use a good barrier cream and wash your hands soon as possible,do not under estimate the dangers of some of the products we use in our model making,build and fly safely.
                    • Greyhead
                      • Oct 2004
                      • 581
                      Nice work Dave, with those carbon fibre tows I wouldn't mind betting it's a fair bit stronger than the original!!
                      Grahame
                        Hi,
                        Your fuz repair thread has really helped me since i snapped my pat teakle ASW17 fuz in the same place.
                        Just wondering what paint you used for priming and final spraying... did you get a good colour match??
                        PLease post a pic of finished article.
                        Many Thanks
                        Ben
                        • Glider Guider
                          • Oct 2004
                          • 88
                          Hi,Your fuz repair thread has really helped me since i snapped my pat teakle ASW17 fuz in the same place.
                          Many Thanks
                          Ben
                          Ben
                          The fuselage is awaiting better weather before I spray but I'm going to use Halfords aerosol White Primer and Spectrum top coat. When spraying I use fast thinner from the local motor factors for Spectrum and Solarlac as it’s a thousand times cheaper and works just fine. I give a couple of coats of primer which is rubbed down, then give it a quick flash over with black and rub down, by doing this you can see the imperfections as black marks which can be given a bit of filler or rubbed out.
                          Unless you know the original paint you'll struggle to get an exact match in white, I'm going to re-spray the whole model not just the damaged areas. You might get away with a close matching paint between fuselage and wings but I doubt that just spraying the tail section will give satisfactory results but try it and see if it stands out, you can always continue with the rest of the fuselage if it doesn’t work.
                          I will be posting a photo when it is finished.
                          I’m please my article has helped you - it makes it all worth the while.
                          • Glider Guider
                            • Oct 2004
                            • 88
                            I saw my first swallow today over Swithland Reservoir in Leicestershire which means that the spraying season can’t be far away. The PIK 20 fuselage is going to be boring white so I dusted it off and gave the areas of repair a quick flash of black paint.
                            Why? This is then removed with wet & dry and all the minor imperfections that are normally invisible until you have just applied the final coat become easy to see and fix with a dab of acrylic stopper.
                            It was as I sanded away the black paint that I realised my mistake – the black paint doesn’t show up at all on the carbon tows I used for the repair, so after that stopping is applied and rubbed down I’ll give it a coat of a different colour. Now I’ve got some white paint somewhere ……..
                            [ATTACH]7556.IPB[/ATTACH]
                            [ATTACH]7555.IPB[/ATTACH]
                            [IMG]/monthly_2005_04/57272b6e1d24b_P4030026(568x426).jpg.d24987684c7879 f1e72d1e43c8378c0f.jpg[/IMG]
                            [IMG]/monthly_2005_04/57272b6e1c303_P4030025(568x426).jpg.aef959028ac068 0e68bf84b8a02da971.jpg[/IMG]
                            [ATTACH]12850.IPB[/ATTACH]
                            [ATTACH]12851.IPB[/ATTACH]
                              I saw my first swallow today over Swithland Reservoir in Leicestershire which means that the spraying season can’t be far away. The PIK 20 fuselage is going to be boring white so I dusted it off and gave the areas of repair a quick flash of black paint.Why? This is then removed with wet & dry and all the minor imperfections that are normally invisible until you have just applied the final coat become easy to see and fix with a dab of acrylic stopper.
                              'Halford's' do a good spray and fill paint aswell. covers and fills any small imperfections at the same time. I have used it on model boat hulls before the final sanding. :zoo_taz:
