I did one a couple of days ago I needed a length of metal rod for the DB5 replacement hideous crank and camshaft all moulded from a single piece of plastic anyway found what I was looking for put in the vice and preceded to cut the said steel rod well no you see the rod was titanium so all it did was remove all the teeth from the hacksaw so I resorted to using the wire cutter portion of a pair of pliars which just about managed to put a nick in the rod so then resorted to vigarously bending the rod at the point until it snapped which it did without warning and as I was wearing shorts at the time and using my leg as a lever point you can guess what happend yep the metal snapping slashed accross my leg with a nice long scratch type cut to boot at least the rod was the correct length
Regards
Colin
Regards
Colin
