Need help guys, trying to damage a TKS in a fire fight with a Panzer I. Need to do bullet ricochets and one kill shot though the side of the TKS, any ideas?
Bullets
GuestTags: None
Originally posted by \Need help guys, trying to damage a TKS in a fire fight with a Panzer I. Need to do bullet ricochets and one kill shot though the side of the TKS, any ideas?
For shell penetration same principle, but use something of the correct shell diameter such as a small screw driver or nail and push this right through the plastic.
I used this method on the tank in my 'Dead Elefant' album pictures if you fancy seeing the effect. No bullet strikes though!
I hope this has been of some use Jay.
Ron -
I'd check T'internet for shell strikes on armour as I've found all sorts of images there. As for bullet strikes I have seen plenty of pictures and (unfortunately,as a young boy in Biafra) plenty of the real thing and modellers almost invariably over do them. A typical rifle calibre machine gun round makes a hole about the same size as the round,not like in the movies! You are trying to make a hole,in your scale, of around 7-10mm diametre. A heavy machine gun still only makes a hole about 13mm diametre. At 1/48 an 8mm hole is less than 1/5 of a millimetre across!
SteveComment
If you have a look through the gallery on this site there are a couple of shell deflections on page five to give you an idea of what they look like:
Tiger I Information Center | PanzerKampfwagen VI: The Legendary Tiger IComment
