KLEAR, take a look!
GuestTags: None
Nice one miks. I couldn't agree with you more. One tiny detail. It stated to be used as a cheap varnish because there was not a readily available acrylic varnish at the time.
Or so the stegosaurus told me....
Ian M -
Originally posted by \Nice one miks. I couldn't agree with you more. One tiny detail. It stated to be used as a cheap varnish because there was not a readily available acrylic varnish at the time. Or so the stegosaurus told me....
Ian MComment
Excellent Vid Mike,thanks for taking the time to Klear that up for us! On a side note you mentioned ca glue for securing canopies the foam safe (gold label here in the States) does'nt fog at all just my .02Comment
Originally posted by \Excellent Vid Mike,thanks for taking the time to Klear that up for us! On a side note you mentioned ca glue for securing canopies the foam safe (gold label here in the States) does'nt fog at all just my .02
What i've found however, I never apply straight from the tube / bottle to the part, drop onto a piece of card on the table, and use my MkI sewing needle chucked in pin vice to tactically apply drops, as I said in the video, never once fogged a clear part, I use superglue on everything clear, lenses, canopies, headlights, taillights, car windows and once even an entire 1/144th Sweet Hawker hurricane which was moulded in clear styrene and looked too good to paint.
I guess we must have some foam safe stuff given the amount of foam RC models floating, (pardong the pun), around now, thinking back when I was flying my Ikarus piccolo, I recall a guy with a Bell 222 and a Huey bodyshell, they were made of Depron and as he tried to repair then huey tail after a bad landing discovered that superglue melts depron foam quite aggressively, there were a few choice words.Comment
Brilliant, well said! I stuck a bottle of old Klear on eBay a year or so ago when I was moving house and couldn't believe that the BIDDING went over £25 for it... I've got my original bottle which is still about 2/3rd full plus I have a bottle of the new stuff sitting on the shelf. Thinning paint.. whatever next!!! I did experiment with it and pigments to see if it would make glossy "wet mud" but that didn't really work well. I hear it can also make floor nice and shiny!Comment
Watered pva is pretty good for that wet mud look.
But, hang on, it can be used to make your floors shiny, dammit, I didn't realise, that's got to be worth £20,
I wonder what other household uses SC johnsons modelling range can do, lolComment
The funny thing is , if you work it out , £20 is about right for 500 ml of acrylic gloss varnish (based on Vallejo 60ml bottles at around £2.75 ea) . Still a bit silly though , when you can get the new stuff for £3.50 , now that is a bargain!! (personally i prefer the smell and clear colour of the old type ,plus it IS slightly different - its a bit more viscose) tonyComment
Originally posted by \The funny thing is , if you work it out , £20 is about right for 500 ml of acrylic gloss varnish (based on Vallejo 60ml bottles at around £2.75 ea) . Still a bit silly though , when you can get the new stuff for £3.50 , now that is a bargain!! (personally i prefer the smell and clear colour of the old type ,plus it IS slightly different - its a bit more viscose) tony
Xtracrylics, I mention in passing as I have some and it's superb in cost and operation (AND is completely dry and cured enough to decal and oil wash onto in 15 minutes as an added bonus) is 300ml=£5, will thin out to AT LEAST twice it's volume, (with water) and still be milky airbrush consistency so 600ml=£5=almost as cheap as the new Klear at £3.50=750ml
100ml=£3.25, (prices from hannants who I believe are the owners of the Xtracrylics range? corerct me if wrong), £3.25 x 2.5=£8.12=250ml of varnish, doubled in water for thinning to spray, (thicker than Klear) consistency=£8.12=500ml.
So even at it's pricier option in 100ml bottles, still less than half the price of old stock exhorbitant prices.
If you actually thinned the stuff to Klear consistency, it's even cheaper, most likely cheaper even than the new stuff for a 750ml bottle quantity based on the 300ml price.
If you took your Vallejo and thinned to consistency into account I think you'd find that the odds were not the same.
I disagree on the viscosity, as you see in my video, i have the 2 side by side and both being in the same room and same temp I honestly can't see that one is thicker than the other, even if the new one was a smidge thicker, that's juat another bonus, a splash of water to thin it further and you have 800ml for £3.50,
I brush paint either, (whichever is closer as I lean over to pick up a bottle when I pre-decal coat) as I realised it coated and settled cleaner than spraying without flooding or pooling while aiming for that 'wet coat' and any slight excess can be wicked back with the bristles and have honestly not noticed any difference in operation or application.
As for preference, if you can justify the extra £16.50 per bottle, (or £3.54 per 100ml-based on a cost of £20 per bottle which is a low average currently. £4.00 per 100ml-old - £0.46 per 100ml-new), then thats fine.
The point of the video wasn't to suggest people don't buy it IF they know the differences and would rather have the older stuff, but to make people who had been convinced that they absolutely MUST have the older stuff as the newer stuff will not do what the older one does, (which clearly is either an outright lie or misinformation), aware of the actual facts and that the new stuff will do them exactly the same job leaving them £16.50 to spend on a couple of Airfix 1/72's and some paint and a brush or two.
I'm all for encouraging newcomers and onwardly encouraging modellers still discovering those little tips to continue, expand their knowledge and above all enjoy, theres too much stuff in the world convincing people they need things they don't without modelling going that way too, it was always a cheap fun hobby to me with the option of splashing out on specialist or expensive if and when you choose to, not because someone says you need to.
Peronally, I prefer also the lack of perfume in the older one, only because if coating a large model the perfume lingers awhile in my modelling cave but it means opening the window to air it more frequently, the big question is, do I like it £16.50, minimum worth, the answer is, No
Reminds me of a Newsthump poll for the iphone 5 I saw recently, choose from 2 questions, are you going to buy the new iphone 5 which is basically an iphone 4 with a different name
a) Yes, I have a bundle of 50's burning a hole in my wallet
b) No, i'm not a moron
Originally posted by \Its great for treating the shower cabins glass door. Ian M
Apparently it's good for wooden floors too, though at that price you've REALLY gotta love your wooden floors!Comment
In the video you say that there is no difference apart from the colour, the smell and the bottle, do you mean chemically? Practically? I'm not sure what you're basing this on
How did you compare the two? Saying they're the same without any evidence is just adding another opinion to this never ending argument
As an aside, my "old" Klear has quite a pleasant smell :thumbsup:Comment
