Hi All just wanted to share this one with you... Ever wanted some netting or fencing in a particular scale?
i needed some and came up with the below. It has worked well for me and you can vary the width of the netting or fencing.
materials:
2 lice Combes
1 piece of hard
Glue epoxy and superglue
Cotton or Fishing line
And a bit of bravery
Measure the length of the Combes, cut hard board in a square to the appropriate size, glue the Combes to the hard board.
Using the comb teeth as width guides take the material you wish to use and weave from one side to the other, when done weave from the opposite side until required size is achieved.
now this is the brave bit... Dip your finger in some superglue and run it along the line of the thread, you may have too do this several times depending on the netting material you use.
leave to dry and cut edges to release..hay presto there you have it.
[ATTACH]57719.vB[/ATTACH][ATTACH]57720.vB[/ATTACH]Here is one I made earlier using fishing line, hope it helps.
[ATTACH]59638.IPB[/ATTACH]
[ATTACH]59639.IPB[/ATTACH]
materials:
2 lice Combes
1 piece of hard
