stripping paint
    stripping paint
    I was given an excellent tip about stripping paint by dipping it in dettol for a few hours. then you dip the stripped kit in just water and brush over with a tooth brush, then wash in soapy water.
    Scott.
    Interesting. I will file it away.
      Couple of articles I found on stripping acrylic paint.
      The second one uses detol & the author has tested 7 explained how to go about it.
      5 liquids that can remove dried acrylic paint from surfaces
      MAXSTAR'S CLOUD - A World of Warhammer 40K: Tutorial: How To Remove Paint From Plastic Models
      To save embarrassment I would test first on a trial bit of plastic with the glue used & with the same finishes. Also make sure any items not plastic fitted are not affected.
        Just to add to this I have just stripped paint off my tamiya model with Fairy power spray, left for a few hours and removed with a toothbrush.
        • Gern
          • 9212
          Just to add to the mix:
          http://www.scale-models.co.uk/painting/17423-how-strip-paint.html
          Gern
            Bleach and Tesco value multi purpose cleaner work well. Again overnight or for a few hours.
            Stuart
              I have just used IPA and a cotton bud and at times a paper towel. I could not soak the part in anything because it was one of the horizontal stabilisers on a Spitfire, painted with the usual 5 or 6 coats of paint and varnish. (I smudged some aluminium on it with dirty fingers!) It worked down to the plastic, but slowly, needing a lot of rubbing.
              • takeslousyphotos
                • Apr 2013
                • 3900
                I suppose shotblasting is out of the question ?
                Peter
