Help
    Help
    Went to spray this with clear lacqure but it turned out gloss, i needed to spray it to stop the leaves faling of as they are real.
    [ATTACH]64645.vB[/ATTACH][ATTACH]64646.vB[/ATTACH]
    I need it with no shine as i want to use it in an exhibition on July 13 & i so want to take it.
    Any help would be nice.
    [ATTACH]65836.IPB[/ATTACH]
    [ATTACH]65837.IPB[/ATTACH]
    You may be able to see my dilemer better in these pic's.
    [ATTACH]64648.vB[/ATTACH][ATTACH]64649.vB[/ATTACH][ATTACH]64650.vB[/ATTACH]
    The lacqure turned out to be gloss.
    [ATTACH]65839.IPB[/ATTACH]
    [ATTACH]65840.IPB[/ATTACH]
    [ATTACH]65841.IPB[/ATTACH]
    • AlanG
      • 6296
      Did you shake the bottle of varnish enough? Sometimes if you don't shake it enough it will leave it glossy instead.
        Yep always do i think the lacqure was gloss.
        • Andy2035
          • Aug 2011
          • 730
          Hi John,
          Personally I think it looks great as it is, and is well worth *****, but, if you still want to dull it down, can you not just spray over the top of it with a matt lacquer, are you using spray cans or an airbrush...
          Andy...
