I am trying to use Super Glue to fix the tiny undercarriage struts of my 1/72 Lancaster. I have used it once before to stick the aerial wire to the mast and tail of two Spitfires. It solidified in about 5 seconds. But now, in doing some tests on gluing little pieces of plastic together, it will not fully solidify, despite leaving it alone for many minutes. I am using Deluxe Materials' Rocket Hot (1 to 5 secs bonding time).
Using a cocktail stick, I put a small drop on one part and place the other part on it and wait. The parts (the test parts as well as the undercarriage parts) are about 1 mm diameter rod. A second way I do is to put the parts together and then add a small drop of the glue from the stick.
The parts adhere but so weakly that they can easily be pulled apart. The glue is soft and there is no strength in the joint.
Am I doing it right? I bought the Superglue about April this year. Can it go off so quickly?
