Hi guy,s and girls,
After a couple of questions about the walls of my Dutch building, I thought, I would show you how I did that. There are definitely a lot of other ways like pouring them with plaster making them out of wood buying a model like the Miniart ones or Verlinden and so on, but I like to scratch so I make them myself.
If anyone like to join in please do, and don’t hesitate to ask any related questions.
I made a little template for a brick wall with a window and a door in it.
You can download it for A4 and US Letter size
So now to the what do I need question,
1. Piece of depron foam best is 6mm or blue foam or something that is equal to that.
2. Sharp knife or Scalpel
3. Some foam friendly glue
4. A ruler
5. adhesive tape
6. Some permanent markers with a small tip
7. Some paint, best is red for the bricks but any color will do
8. Plaster to make the mortar between the stones
That’s it
, and so we cut out the whole template.
here are the pictures
[ATTACH]73182.IPB[/ATTACH]
[ATTACH]73183.IPB[/ATTACH]
[ATTACH]73184.IPB[/ATTACH]
After printing out the templates we put them on the foam with some adhesive tape
[ATTACH]73185.IPB[/ATTACH]
then we take the scalpel and cut in the small side of the stones not to deep 1MM is enough
[ATTACH]73186.IPB[/ATTACH]
now we put the ruler on the long side and cut again 1MM deep
[ATTACH]73187.IPB[/ATTACH]
[ATTACH]73188.IPB[/ATTACH]
after a couple of lines it would look like this
[ATTACH]73189.IPB[/ATTACH]
and wen we are done this is what it should look like
[ATTACH]73190.IPB[/ATTACH]
after cutting the whole wall we take the marker and we start to draw each brick separately.
more later on
Cheers Richi
[ATTACH]73180.IPB[/ATTACH]
[ATTACH]73181.IPB[/ATTACH]
4. A ruler
5. adhesive tape
That’s it
more later on
Cheers Richi
