Just another quickie from me helping to save cash and have a bit more fun with creating something with your own personal touch.
I'm all out of cash at the mo due to 6 kids needing their Xmas money and the 'dog' needing surgery (not effin' cheap) so can't warrant buying any kits at the mo and am spending my time adding to the MASH dio.
Anyhow for this topic you'll need
A trip to a tree
an old kitchen sponge
some cheap glue
some spare brown and green paint
a length of garden twine
some wire and a pin.
Total cost ...... pennies!
Get twig from tree and cut to shape and size, stick a headless pin in the bottom (this will help the tree to stay upright on the diorama whilst the glues drying, or if you use balsa bases like me then you can stick it anywhere and move around as needed till it looks right)
[ATTACH]74882.IPB[/ATTACH]
[ATTACH]74886.IPB[/ATTACH]
I try to have a few in stock
[ATTACH]74884.IPB[/ATTACH]
[ATTACH]74885.IPB[/ATTACH]
Get some short lengths of twine and twist some wire round the middle, splay out the ends of the twine to form twigs, spray (or brush) adhesive on the twine and add the scatter by sprinkling it over the tacky surface.
the scatter is made by ripping up just the sponge from an old kitchen scourer, popping it into a suitable container with some water and using a blender or similar to chop it up into little bits, you can add paint to the water to colour it then or you can paint/spray it later when dried as i have done here
[ATTACH]74887.IPB[/ATTACH]
A second way is to just splay out one end of the twine and glue/sprinkle/paint as above.
[ATTACH]74888.IPB[/ATTACH]
[ATTACH]74889.IPB[/ATTACH]
Heres a few before and after being painted, i used a red oxide as a base (not spraying too fully) and then a light green over the top to give the impression of autumn colouration
[ATTACH]74878.IPB[/ATTACH]
[ATTACH]74879.IPB[/ATTACH]
A close up of the blended sponge effect and paint
[ATTACH]74883.IPB[/ATTACH]
To attach them to the twig i drill holes for the wire to fit into and glue into place.
for the twine version i split the wood and then place the twine 'stem' (after being cut to size) into the split and glue it together.
[ATTACH]74890.IPB[/ATTACH]
[ATTACH]74891.IPB[/ATTACH]
The finished job
[ATTACH]74892.IPB[/ATTACH]
Hope this is of use and help to some of you
[ATTACH]74880.IPB[/ATTACH]
[ATTACH]74881.IPB[/ATTACH]
[ATTACH]74893.IPB[/ATTACH]
A trip to a tree
some cheap glue
The finished job
