filler/putty
    filler/putty
    Heyy, I was raking through my loft and found my 1/72 airfix Concorde, my actual first ever model, it's an absolute mess so i thought i'd make it look nice and hang it in my room. So i was using some filler to fill the gaps tht join the wings to the body, I left it for a few days and began sanding, but wen i sand i always ends up with big chunks been pulled out and an uneven surface. How exactly do you pro modelers fill the gaps and make it smooth and perfect?
    Thanks Sam
    oh and what mask is the best? I'm using a liquid mask from hobbycraft but it never seems to work properly :/
    Sam
    • stona
      • Jul 2008
      • 9889
      I use Tamiya putty for small gaps but it won't fill yawning caverns. Big gaps may need some plastic card or stretched sprue laying in and glueing before filling and sanding. An epoxy putty like Milliput is sometimes useful,it will fill a gap and doesn't shrink.
      I always mask with Tamiya tape (or similar) and Blu-Tac if called for.
      • colin m
        • 8759
        • Colin
        • Stafford, UK
        Hello Sam,
        Did you apply the filler over gloss white paint I wonder (being concorde) If so this may be the problem. Filler probably won't stick too well to a gloss surface. Is so, sand back the paint to bare plastic, and try again.
        I use plain old Humbrol filler, It dries very quickly, which might be a problem for some, but at least your not hanging around for ages !
        I'm with Steve on Tamiya tape - it's really good stuff. But I tend to use normal masking tape for holding bits together, saving the Tamiya for the important jobs.
        Regards
        Colin M.....
          Thanks Stona, I've used blue-tac before but found it difficult to remove it from windows but i'll try again. Yes it was painted with gloss a few years ago, i'll get it all sanded and get some of that tamita tape. Also is their any certain type of sand paper to use or is any okay? because I'm using a medium grit one at the moment.
          Thankyou for the info guys
          Sam
          • stona
            • Jul 2008
            • 9889
            Hi Sam,I don't often do windows except on the rare occasion that I build a bomber (there's been a Tamiya 1/48 lancaster in my cupboard for far too long). My technique is to mask the window with tape before I fit it to the model. Once I've got all the paints,varnishes etc on I remove the tape to reveal,hopefully,a lovely clear window.
            I've never really got on with liquid mask either though some people swear by it. It tends to make a mess and end up in places where I don't want it LOL.
            For sand paper I use wet'n'dry from Halfords,mostly grades between 800 and 1500 grit.
              Exactly my problem steve! The mask just runs all over and with the recent heat it hardens in seconds if the coats are too thin, which then pulls off when you apply another coat. You just can't win with it :/
              Sam
                • 18271
                Liquid mask is a pain! It can be used to great effect for doing chipping and the like. As for masking windows I have had only limited success. The thing is that it only needs to be a very thin film. as long as the part you want masked is totally covered it will be fine. I tend to give the window a blob off a tooth pick/ cocktail stick and then drag it around so it fills the whole area. Leave to dry then just give it a blob in the middle, this makes grabbing it with tweezers easier!
                If a kit has small windows; port holes on a boat, windows in the side of an aircraft fuselage, I have been known to leave them out and after the model is painted use Microscales micro klear to fill the hole. As it dries it turns clear but a perfect window glass it is not. The effect is good though and you do end up with a very thin window.
                Larger windows I mask before I put them in, like Stona.
                Filler; I use both squadrons white and Green, also Humbrols. They do dry quick though. You can thin them down with liquid glue and paint it on with a brush. This is very good for pin marks and other scratch marks as you can put it right where you need it.
                Big holes/gaps get filled with Milliput.
                  i too have used milliput and it takes a fair old while to dry but if you wet your finger and smooth it over and it gets rid of a lot of sanding.
                    has anyone tried the usual poly filler from a diy shop. I am very tempted to use it for big gaps and ready to sand it. Anyone tried it before?
                      yes I actually tried it a few days ago. The one from b&q, it goes on smooth and is really easy to sand. Only thing i found is that its quite brittle, but tht may vary from product to product.
                      Sam
                        I have started using Super Glue for filling.
                        Not the common super glue found in shops.
                        There is a great selection. Thin, medium & thick. A gel. A brush on. And another manufacturer has a powder you place in the gap & then put super glue on top of the powder. The thin one wicks into small gaps & is good for re-glueing a poor joint.
                        Some are faster to go off some retarded. There is also an accelerator to apply after you have everything else completed.
                        Price to pay if you are not careful. Fingers suddenly become part of the wing or you suddenly lose a finger to your thumb. Joking apart they are lethal if not used with extreme care. Use specs or goggles, store away from children.
                        With care they are great extremely strong & give good results. When they have gone off get down to filing & papering immediately as they get stronger in time, Fast.
                        A new outlet is Filla-Glu Product Range
                        Also I have bought from another outlet but the one above seems to have a number of good innovations & it seems to be better presented for applying.
                        For applying wings it is really strong compared to the poly cements stuff. But you have to be able to set up quickly & be neat & tidy. Like all modelers ???
                        • stona
                          • Jul 2008
                          • 9889
                          Originally posted by \
                          When they have gone off get down to filing & papering immediately as they get stronger in time, Fast.For applying wings it is really strong compared to the poly cements stuff.
                          That first point is vital as the glue/filler quickly goes off harder than the surrounding plastic with inevitable difficulties at the sanding stage. You can soften it with acetone or an acetone based nail varnish remover.
                          I would beg to differ about the relative strengths of the bonds,but a good bond can only be achieved with poly cements if you have two surfaces that match up. It is useless in a gap. A well made joint using poly cement will fill itself with "molten" plastic and not need filling. It will also be very difficult to break apart,CA joints can usually be seperated relatively easily if you apply a shearing force.
                            Also beg to differ Steve. Can only think you are using inferior super glue, the incorrect super glue or not applying it in the right conditions.
                            I tried it on a a discarded model. Poly glue snapped at the joint. The super glue joint not only held but the wing snapped off further down. It does not shrink as it does not have a solvent, as poly glue, therefore has a 100% contact with the material. Look very closely at poly glue joint & you will find that there are minute air bubbles.
                            Super glue providing you use the correct product is used as a gap glue in many industries.
                            The point I was making is that you get at the joint as soon as the glue is hard enough to work. That is in secs of it going off. If you do that I have joints which are far superior to all the other fillers I have used. You must however make sure that you only fill as flush as possible to avoid extra work.
                            Another use which I forgot to mention. Small fragile items such as aircraft masts, machine guns glued to wings, pitot tubes are easily damaged & broken off. If you with a brush type super glue apply a very thin coat to these items the item is greatly strengthened.
                            Lazy calling them superglues as they are Cyanoacrylates.
                            • stona
                              • Jul 2008
                              • 9889
                              Well Laurie we'll agree to disagree.
                              I think at something like a wing/fuselage join a CA glue may well be stronger. These types of joins never have a continuous length of two surfaces in good contact over enough area.
                              It's the reason we have to fill them in the first place. I use CA myself in this circumstance,as I said,Poly cement is useless in a gap.
                              I still believe that along a well prepared seam where you have to mating surfaces a properly applied Poly cement will "weld" the two sides together. I do short lengths at a time and squeeze un til some dissolved plastic oozes from the seam. After allowing time for the join to dry and "outgas" I get a seam which will need scraping but not (9/10) filling. If filling is needed it is usually because I hadn't prepared the mating surfaces as well as I thought I had. I bet we've all been there! I tried seperating such a seam on an old model recently,looking to recycle some internal parts,and ended up breaking the model up. I've just tried seperating to halves of a scrap wing with a more equivocal result,the seam did seperate along about half the leading edge but it took some doing.
                              I agree absolutely with CA's gap filling ability,again,I use it myself. I just wanted less experienced modellers to be aware that you do need to get at it quickly or it can be difficult to deal with.
                              Good tip for strengthening "dangly bits" too. If I had a quid for every pitot tube I'd snapped off........
