Model ballast
    Model ballast
    Hey all,
    Quick tip to add ballast to your tail-sitter aircraft.
    Buy a packet of lead airgun pellets for your ballast needs, it's cheap and should last a while.
    Take a few lead pellets and squeeze them flat with a pair of pliers - this way you can fit in more weight. I then use normal wood glue to fix them into place - the glue dries without reacting with the plastic and neatly holds the lead in place.
    Quintin
  • Alan 45
    • Nov 2012
    • 9833
    Good tip I usually use blutac
    • PaulTRose
      • Jun 2013
      • 6455
      • Tattooine
      i use nuts and bolts, and pack with plasticine since thats so cheap
      Per Ardua
        Hey Alan,
        Blutac works a treat. I simply used woodglue because I had to add the ballast after joining the fuselage halves and I had limited space! Suppose that's what I get for rushing the build, haha!
        • Dave W
          • Jan 2011
          • 4713
          I use pieces cut from a bit of lead roof flashing.
          • PaulTRose
            • Jun 2013
            • 6455
            • Tattooine
            im sure i remember reading somewhere that ca glue reacts with lead.....slowly!
            it sort of grows a coating which as it expands will cause fuselage halfs to crack open.....but it does take years
            Per Ardua
            • peterairfix
              • Jul 2012
              • 11074
              I use copper coated steel shot from air guns i got 1500 for just over a fiver my last lot lasted for ten years and i still have a 1/4 left.
              Peter t
                Some good tips here I use plastacine usually as it can be moulded in to nooks and crannies.
                  got some fishing bombs from go outdoors cheap. fit in nose of my 1/72 tornado. 7 grams each one
                  http://www.gooutdoors.co.uk/dinsmores-arlesey-bombs-7g-fishing-match-weight-p101025
                    • 18266
                    Lead flashing for me as well. Chop it up into tiny bits and I too try to avoid the use of CA and either hold it in place with a blob f blue tak or white glue.
                    • Lee W
                      • Feb 2014
                      • 4654
                      • Lee
                      • Sherborne
                      I don't bother with either....its cheaper :P LMAO
                      Joking, I use whatever's in the kit...as and when I get oneo_O
                      Lol
                      Lee
