I have completed the Valkyrie , I think I did a bit too much on the chipping , I can get carried away sometimes,
Not a bad kit but not a great one , it did need a bit of taping up for the rear stabilisers to meet the the rear cross fin and I did have a slight bend in the mid section causing one wing to be higher than the other , the front canopy needs a fare bit of filing down on the inside for it so sit properly if you put the figure in as the arms stick out a bit ,
The instructions are odd as there are no part numbers so you have find them by sight and one piece is missing from the instructions altogether and it's a needed part if you want the canopy closed
Decals are a nightmare, they are all on one sheet so you have to cut them quite closes to the edge so you don't have too much overlap , this is a problem as you hav nowhere to hold them with
Now my mistake! I trod on the front canopy breaking it in half so now it has a big crack down the front windscreen
Here's the pics comments welcome
[ATTACH]121954.IPB[/ATTACH]
[ATTACH]121955.IPB[/ATTACH]
[ATTACH]121956.IPB[/ATTACH]
[ATTACH]121957.IPB[/ATTACH]
[ATTACH]121958.IPB[/ATTACH]
[ATTACH]121959.IPB[/ATTACH]
