Completed Slave I
  • Tommy
    • Mar 2007
    • 142
    #16
    I agree with all.. a wonderful build!
      thanks tommy.
        • 18266
        Nice One Jim! Love the chipped and flaking paint.
          thanks ian.
            The detail, paint job and all around skill involved in this build is a credit to you Jim and Boba Fett. Simply amazing job!!! GO SLAVE 1 !!!!
              thanks bucks. i appreciate the compliment.
              • Centurion3RTR
                • Jan 2009
                • 2093
                #22
                Whoa!! I missed another beauty. Nice work there Jim, sorry i missed it bud. Love the weathering, just right for Boba Fett.
                Have fun, John
                  not a problem john. thanks, i like seeing my old projects come back in my inbox. always a nice surprise.
                  thanks
                  • InFlames
                    • Feb 2012
                    • 466
                    #24
                    Great looking model! :beer:
                    • mossiepilot
                      • Jul 2011
                      • 2272
                      #25
                      A great build and masterful paint job, all it needs now is a star field behind it to set it off perfectly.
                      5 stars.
                      Tony.
                        thanks Flames and Tony. I do have the Finemolds Millenium Falcon in my stash. I ordered a bunch of paints for it that were not the color i thought they were going to be when they arrived, so it's been pushed back again (aside from me being terrified to start it with all the small pieces...). I think whenever i finish it, i'll have a friend of mine photoshop Slave I following the Falcon through the asteroid field from Empire. That could be cool.
                        Or try and do something with the landing pad that they both use in Empire in Cloud City. That could also be cool. But again, scared to start it... gotta do it sometime i suppose though.
                          i recieved my fine molds version just this friday gone,expensive but from what everyone was saying its a cool kit and pretty accurate,also after having an airfix (which is not on the back burner) i know fine molds version is gonna be well wortth every penny i spent on it.
                          if yours took 2 months i might have to wait till another time to undertake the task of constructing it,some nice chipping technique you employed there,mind if i ask what method you used to achieve the finish,i have some maskol and i used it on the airfix and it was pretty good for the effect.
                            thanks saleem. it only took me two months due to me having to redo the hull because of bad color choices. but for the chipping effect, i used liquid frisket. I'm pretty sure that's basically the same thing as maskol. i was unable to get some of it here in the states, but the liquid frisket worked great, dried pretty quickly and peeled right off. i had read that maskol could attack acrylic finishes. i use tamiya paints, and the frisket didn't attack it. just throwing it out there, something you might want to be aware of.
                            good luck.
                              Nice work with colors. :bye:
                                well, i finally worked up either enough courage or stupidity to pry off the canopy to fix it. since i started using future klear on my canopies, i've been wanting to go back and fix this since it always bothered me. I used a brand new #11 blade and gradually ran it through the joins to eventually cut through the glue to pop the canopy off.
                                then to get the old tinted clear coat off i soaked the canopy in some oxi-clean. if you ever have to remove acrylic paint, get some oxi clean. that stuff is fantastic. i then wet sanded the whole canopy with 1500 grit wet sandpaper and dunked the whole thing in future klear maybe 6 times over a couple day span. i think it looks a million times better, only problem is i can't get any good pics of it because it's so reflective now from the future klear.
                                [ATTACH]55998.IPB[/ATTACH]
                                [ATTACH]55999.IPB[/ATTACH]
                                [ATTACH]56000.IPB[/ATTACH]
