50th Anniversary Moon Landing Saturn V 1/72 Dragon Models
  • flyjoe180
    • Jan 2012
    • 12429
    • Joe
    • Earth
    #16
    Looking good!
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #17
      Originally posted by Bigfoot57
      Saturn V build part 7
      Hello again sorry for the lateness of this continuation but I have had to find and locate a drawing program learn how to use it and finally produce a scaled printout of the parts required so see the pictures below
      1st off cut out cardboard strips mixed up the paint colour painted them then added vertical part of the i beam to 2 strips to form a complete capital I beam which were then glued into the rocket stage in 8 equally space sections ready for the arcs to attached to them
      Next found and downloaded and installed a vector drawing program calked Isketch which is freeware and almost on par with adobes expensive offering anyway after installing had to learn how to use it to produce the internal structures of my build
      So here is the resulting drawing now in word ready for printing I use words import pictures option as it is easier the size the object and print it than using the designing program
      After that the images are cut out discarding the black area and then fitted as arcs into the interior of the stage
      Finally the end pieces are added to finish off this part of the build next will come some more internal junction boxes etc this is price you pay for showing the rocket in its disassembled form as at either Johnson Space Centre or KSC much more to follow
      Regards
      [ATTACH=CONFIG]n1126096[/ATTACH][ATTACH=CONFIG]n1126096[/ATTACH][ATTACH=CONFIG]n1126094[/ATTACH][ATTACH=CONFIG]n1126095[/ATTACH][ATTACH=CONFIG]n1126097[/ATTACH][ATTACH=CONFIG]n1126098[/ATTACH][ATTACH=CONFIG]n1126096[/ATTACH][ATTACH=CONFIG]n1126087[/ATTACH][ATTACH=CONFIG]n1126088[/ATTACH][ATTACH=CONFIG]n1126089[/ATTACH][ATTACH=CONFIG]n1126090[/ATTACH][ATTACH=CONFIG]n1126091[/ATTACH][ATTACH=CONFIG]n1126092[/ATTACH][ATTACH=CONFIG]n1126093[/ATTACH][ATTACH=CONFIG]n1126094[/ATTACH][ATTACH=CONFIG]n1126095[/ATTACH][ATTACH=CONFIG]n1126096[/ATTACH][ATTACH=CONFIG]n1126097[/ATTACH][ATTACH=CONFIG]n1126098[/ATTACH]
      HI Colin this is some very detaied work an looks very good it really sets the model off very well done I like very much
      chris
      • rtfoe
        • 9094
        #18
        Hi Colin, using print outs is very clever. Build is looking good. Built a Revell kit when I was in my teens. Will have to pay crazy money for a kit now.
        • Bigfoot57
          • Jun 2015
          • 1103
          #19
          Saturn V Build Part 8
          Finally finished the engine section with the adding of access doors and I think they call them gimbaling arcs as well as the hold down clamps which have now been painted to match the background
          Also added umbilical connections and vent outlets one thing I need to know is how many of these were on the stage I have done 4 one in each section but it may only be one required
          Next up will be adding internal details to the remaining stage 1 sections along with adding details to the tank tops and bottomsClick image for larger version
ID:	1128485Click image for larger version
ID:	1128486Click image for larger version
ID:	1128487Click image for larger version
ID:	1128488Click image for larger version
            • 22771
            #20
            Very nice work.
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #21
              HI Colin its comin on great this must be the most detailed model of a saturn V that i ever seen very well done for your effort an im likein a lot more please
              chris
              • Bigfoot57
                • Jun 2015
                • 1103
                #22
                Saturn V Part 9
                Sorry for lack of update on this build but a lot of head scratching and scratch building has been required so here goes
                Next I tackled the interstage ring that separates the 1st and 2nd stages most of this is my own take on what found on the net and other research and some of it may be completely wrong but its the best I can come up with
                So 1st off scratch build the main struts of which there are 8 then add the circular arcs that represent the internal rings along with the two end complete rings next the control and power boxes are constructed and added to the stage next I added some piping just to give extra detail finally 4 fuel pipes were added made from articulated sections of plastic drinking straws I’m waiting for some better quality ones to arrive and will replace these when they do
                You can see how they link in the last photo of this section I also constructed another fuel tank end cap just in case I need an extra one later on
                Next will be the disaster Dragon call the 2nd stage engine assembly I’m still waiting for additional items to arrive before I post the build diary on that particular section
                Regards
                Colin
ID:	1130349Click image for larger version
ID:	1130350Click image for larger version
ID:	1130351Click image for larger version
ID:	1130352Click image for larger version
ID:	1130353Click image for larger version
ID:	1130354Click image for larger version
ID:	1130355Click image for larger version
ID:	1130356Click image for larger version
ID:	1130357Click image for larger version
ID:	1130358Click image for larger version
ID:	1130359Click image for larger version
ID:	1130360Click image for larger version
ID:	1130361Click image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #23
                  VERY DETAILTED WORK Colin spot on i think an it looks real
                  chris
                  • Richard48
                    • 1897
                    • Richard
                    • Clacton on Sea
                    #24
                    Wow ive missed this one.Some fine scratchbuilding wizardry in evidence.
                    Nicely done Colin.
                    Rich.
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #25
                      Saturn V 1/72 Dragon Build Part 10
                      Hello again and welcome back to the continued saga of this build
                      1st off redid the interstage fuel piping as original design was garbage
                      Next comes the disaster Dragon calls the 2nd stage engine assembly virtually every part of this is.wrong mine may not be perfect but it’s a lot more accurate than Dragons
                      Right so 1st to go were the shoulder mounts on the engine mount these were sawn off and the resulting holes covered with 10thou plastic card next the heatshield was discarded and a new one constructed along with all the mounting struts made from 1mm carbon fibre rods painted silver
                      New engine cutouts were constructed again from plastic card next I tackled the engines themselves first giving them a basic colour before adding detail then using various plastic and copper beads obtained from ebay additional tanks were added the smaller copper coloured ones I then coloured them green using a sharpie pen this gave a metallic green sheen to these details
                      Finally additional piping was added to the engines using old audio signal lead cable painting silver
                      Next using the articulated plastic sections of drinking straws I constructed the main feed piping from the base of the engine ready to be plugged into the engine mounting as it was put together additional piping was also added at this stage as well finally in constructing this new version I had to create an additional 30mm extra length on the stage part that connects the 1st and 2nd stages together to accommodate the extra length the new engines assembly this was fun as I also had to add around 80 1mm 30mm card strips to simulate the ribs as on the original part and the last part was to paint and fit the lox / lh2 tank top see attached photos for additional visual detail
                      As a comparison there is how Dragon supplied the 2nd stage engine assembly and how my version differs admittedly the dragon one is unpainted but you can see why I scrapped it and built my own
                      More photos follow these
                      Regards
                      ColinClick image for larger version
ID:	1131027Click image for larger version
ID:	1131029Click image for larger version
ID:	1131030Click image for larger version
ID:	1131031Click image for larger version
ID:	1131032Click image for larger version
ID:	1131033Click image for larger version
ID:	1131034Click image for larger version
ID:	1131035Click image for larger version
ID:	1131036Click image for larger version
ID:	1131037Click image for larger version
ID:	1131038Click image for larger version
ID:	1131039Click image for larger version
ID:	1131041Click image for larger version
ID:	1131042Click image for larger version
ID:	1131043Click image for larger version
ID:	1131044Click image for larger version
                      • Bigfoot57
                        • Jun 2015
                        • 1103
                        #26
                        Saturn V 1/72 Dragon Part 10 2nd set of photos Click image for larger version
ID:	1131051Click image for larger version
ID:	1131052Click image for larger version
ID:	1131053Click image for larger version
ID:	1131054Click image for larger version
ID:	1131055Click image for larger version
ID:	1131056Click image for larger version
ID:	1131057Click image for larger version
ID:	1131058Click image for larger version
ID:	1131059Click image for larger version
ID:	1131060Click image for larger version
ID:	1131061Click image for larger version
ID:	1131062Click image for larger version
ID:	1131063Click image for larger version
ID:	1131064Click image for larger version
ID:	1131065Click image for larger version
ID:	1131066Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #27
                          Saturn V 1/72 Dragon Part 10 2nd set of photos [ATTACH=CONFIG]n1131051[/ATTACH][ATTACH=CONFIG]n1131052[/ATTACH][ATTACH=CONFIG]n1131052[/ATTACH][ATTACH=CONFIG]n1131052[/ATTACH][ATTACH=CONFIG]n1131053[/ATTACH][ATTACH=CONFIG]n1131054[/ATTACH][ATTACH=CONFIG]n1131055[/ATTACH][ATTACH=CONFIG]n1131056[/ATTACH][ATTACH=CONFIG]n1131057[/ATTACH][ATTACH=CONFIG]n1131058[/ATTACH][ATTACH=CONFIG]n1131059[/ATTACH][ATTACH=CONFIG]n1131060[/ATTACH][ATTACH=CONFIG]n1131061[/ATTACH][ATTACH=CONFIG]n1131062[/ATTACH][ATTACH=CONFIG]n1131063[/ATTACH][ATTACH=CONFIG]n1131064[/ATTACH][ATTACH=CONFIG]n1131065[/ATTACH][ATTACH=CONFIG]n1131065[/ATTACH][ATTACH=CONFIG]n1131066[/ATTACH][ATTACH=CONFIG]n1131067[/ATTACH]
                          WOW Colin your modifacations are really great you must have been studyin the real saturn in close ups to do this very brilliant work an im pleased to see you still postin your work pics on here as i wounderd what an how it was goin but brilliant work keep this goin till the end as i will be followin
                          chris
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #28
                            Saturn V 1/72 Scale Dragon build Part 11
                            Greetings peeps this I just a short one showing the iconic black & white paint scheme for stages 1 & 2 joined together
                            I worked out the pattern on the conical top by using the instructions and counting how many ribs across the pattern occupied then seeing the centre of the rectangle on the conical section aligned with the left hand edge of the lower 2nd stage stripe this gave me 16 ribs either side I then used some tape and cotton thread to form the shape which then gave me the positions for the remaining black patterns
                            So next will be the 3rd stage but I’m waiting for more paint before I can continue any further
                            Regards
                            Colin
ID:	1131225Click image for larger version
ID:	1131226Click image for larger version
ID:	1131227Click image for larger version
ID:	1131228Click image for larger version
ID:	1131229Click image for larger version
ID:	1131230Click image for larger version
                            • flyjoe180
                              • Jan 2012
                              • 12429
                              • Joe
                              • Earth
                              #29
                              Great work Colin, your additional work and scratching is going to result in a fantastic Saturn V.
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #30
                                Regards
                                Colin
                                [ATTACH=CONFIG]n1131225[/ATTACH][ATTACH=CONFIG]n1131226[/ATTACH][ATTACH=CONFIG]n1131227[/ATTACH][ATTACH=CONFIG]n1131228[/ATTACH][ATTACH=CONFIG]n1131229[/ATTACH][ATTACH=CONFIG]n1131230[/ATTACH][ATTACH=CONFIG]n1131231[/ATTACH]
                                HI Colin this saturn you are buildin is proberly the most detailed model ive ever seen built great work lookin forward to seein it finished
                                chris
