Saturn V 1/72 Scale Dragon build Part 18
Greetings peeps hope you are all well as I continue with this build this time it’s the LEM Shroud and my take on it as opposed to Dragons
Before I get started on the shroud I had to add additional detail to the third stage namely additional fuel lines from the top of the tank and some internal structure to the top end of the 3rd stage to finish it off
So 1st off Dragon have moulded this and the adapter section at the bottom in clear plastic now I know why so you can see the Luna Module inside from one side of the rocket and you paint the other side white to represent the actual view you would get
I went for something different I still used the clear section but I have added the petals so you get an impression of what the actual shroud worked and would look like unfolded I kept the clear plastic as it adds rigidity to the structure
So 1st up is to design 2 outer sheathing to fit over the clear plastic using a special design program I found on the net free to use
Having designed these 2 structures after around 6 failed attempts for various reasons I used the one shown in the photos
The LEM upper shroud was cut into the 4 petals bent into the correct shape using a piece of dowel then the outer formers were made from 1mm thick card using a ruler and pen i didn’t bother measuring the strips width as I used the thickness of the pen line as my size guide and detailed the rest of the petals using paper structs this was because the fit of the cones originally was almost airtight they just dropped into place so any extra thickness would result in the covers not fitting correctly
The whole system locks into place using the bottom shroud as the locking section which keeps the petals pushed firmly against the clear plastic and the top of the petals will be secured by a white elastic 3mm diameter I’m using a rubber band at present till the elastic arrives
The petals themselves are attached to the base of the top section of the shroud by way of 3 x 1mm 40mm flexible plastic strips bent in half with one section glued to the petal and the other ends glued to the inside of the clear plastic upper shroud along with some scratch building to represent the hinge system still more is required for allowing the LEM to sit correctly in the structure
Hopefully the pictures will fill in the missing gaps of my waffle
Regards
Colin
Regards
Colin
