1/48th Scale Saturn V
  • StevenRB
    • Oct 2020
    • 320
    Started building Sheri's Saturn V years ago. Bought this from Red Arrow Hobbies. Definitely some manufacturer issues involved necessitating scratch building parts and using different manufacturers to replace less than stellar parts. Using drawings from David Weeks have given me the ability to create more detail than the original version came with. I've also been building much of this in a Starbucks as well. Click image for larger version
  • StevenRB
    • Oct 2020
    • 320
    • StevenRB
      • Oct 2020
      • 320
ID:	1135336Click image for larger version
ID:	1135337Click image for larger version
      Three out of four fin shrouds were noticeably warped. I used a tube of a similar diameter as a mandrel and a heat gun to try and remove the defects but some warping was still evident. I chose instead to scratch build these four units.
        Hang on … 1:48 scale?! Will you need to cut a hole in your ceiling to be able to display it?
        • StevenRB
          • Oct 2020
          • 320
          It will make it with inches to spare. BTW, this is designed to fly.
          • StevenRB
            • Oct 2020
            • 320
            I simply cut out four of these using a supplied pattern from a tube I had to buy.
            • StevenRB
              • Oct 2020
              • 320
              • StevenRB
                • Oct 2020
                • 320
                Then using a pin to mark the upper stringer locations and tape to join the lower and upper marks I drew connecting lines.
                • StevenRB
                  • Oct 2020
                  • 320
                  The beginning of 1mm. square strigers being glued down.
                  • StevenRB
                    • Oct 2020
                    • 320
                    • StevenRB
                      • Oct 2020
                      • 320
                      • StevenRB
                        • Oct 2020
                        • 320
                        • StevenRB
                          • Oct 2020
                          • 320
                          • StevenRB
                            • Oct 2020
                            • 320
                            • StevenRB
                              • Oct 2020
                              • 320
                              Plywood bulkhead epoxied in place.
