1/48th Scale Saturn V
  • boatman
    • Nov 2018
    • 14482
    • christopher
    • NORFOLK UK
    #106
    Originally posted by StevenRB
    I'll be using two of these, one for each parachute. They allow the rocket to come down closer to the launch pad reducing walking distance: https://jollylogic.com/products/chuterelease/
    OH its exspensive though isnt it nr a 130 quid wow
    • StevenRB
      • Oct 2020
      • 320
      #107
      The parachutes will be deployed as normal but with the device wrapped around the folded chute it allows a lengthier free fall period allowing the rocket to land closer to the pad. At a preset altitude, the parachutes will unfold completely.
      • boatman
        • Nov 2018
        • 14482
        • christopher
        • NORFOLK UK
        #108
        YES i like the idea but not the cost
        • StevenRB
          • Oct 2020
          • 320
          #109
          That's why I recommended starting off small. It's much easier on the wallet.
          • boatman
            • Nov 2018
            • 14482
            • christopher
            • NORFOLK UK
            #110
            yea so true
            chris
            • stillp
              • 8094
              • Pete
              • Rugby
              #111
              I built a model rocket in the sixties. It reached an altitude of nearly 4 feet, then dropped to the ground and caught fire. I didn't build another.
              • boatman
                • Nov 2018
                • 14482
                • christopher
                • NORFOLK UK
                #112
                WHAT happened there then Pete hardly a height record is it ?
                chris
                • stillp
                  • 8094
                  • Pete
                  • Rugby
                  #113
                  Remember the Jetex solid-fuel rocket motors Chris? Not a great deal of thrust.
                  • boatman
                    • Nov 2018
                    • 14482
                    • christopher
                    • NORFOLK UK
                    #114
                    YEA Pete i used them a fair amount an yea poor thrust rashio
                    • boatman
                      • Nov 2018
                      • 14482
                      • christopher
                      • NORFOLK UK
                      #115
                      YEA Pete i spent wks building a F86 sabre from a keil craft kit an painted on the dope an then fitting the Jetex solid-fuel rocket motors underneath the fusealarge an then all excited took it out to an open feild as this was a free flight model an held it up an pulled down on the fuse wire an got out my ciggy lighter struck the flame an forgetting that the dope was highly inflamable the plane just went woof AN i was just left holding the jetex motor an i dropped that quick as it started to fire off so not a succes there never seen a plane go up so quick lol
                      chris
                      • StevenRB
                        • Oct 2020
                        • 320
                        #116
                        The Aerotech 54/852 engine casing with screw on end closures. This simply uses a reload kit consisting of solid fuel grains, graphite engine nozzle, ignitor, rubber 'O' rings, delay charge, ejection charge and spacers where needed. Once used you clean it out with a gun brush or similar, dry it out and install another reload kit.
                        • boatman
                          • Nov 2018
                          • 14482
                          • christopher
                          • NORFOLK UK
                          #117
                          [ATTACH=CONFIG]n1136001[/ATTACH]
                          HI Steven good morning to you an yes thats a heck of a engine you got there an this is the one that will power your big saturn 5 ? can we see some more pics of it ? laid out
                          chris
                          • StevenRB
                            • Oct 2020
                            • 320
                            #118
                            chris
                            Good morning to you too Christopher. It's 2:44 AM now and I figured showing the casing itself. When you ask about 'laying it out', are you referring to the entire model?
                            • boatman
                              • Nov 2018
                              • 14482
                              • christopher
                              • NORFOLK UK
                              #119
                              OH sorry Steven so you are about 7 to 8 hrs behind us then ? well then go to bed or you will be tired out an yes i mean could you lay out the whole rocket if you wont mind as id love to see it but do it in your morning plenty of time an sorry again as i forgot you are behind us in time
                              all best
                              chris
                              • StevenRB
                                • Oct 2020
                                • 320
                                #120
                                all best
                                chris
                                You've interrupted nothing so no need to apologize. I was already on here and wide awake. It happens. Being bipolar will do that and just screw up your sleeping schedule. As for the entire stack, I'll have to wait till daylight for better lighting.
