Welcome Aboard '' Doctor Who ''
  • monica
    • Oct 2013
    • 15169
    #31
    hi Joe so glad you like it,
    not very much is seen real as you have only one door opens in about 1/4 way so not much will let you know when i get to that part,
    maybe not have console lights just put 3 on the closed door park may work better and be a bit brighter,
    I do as well,wish it was Tom as well with k-9 that i would lov,
    • monica
      • Oct 2013
      • 15169
      #32
      well have a update, and got the old girl together
      Im quite happy with the color, that it turned out,needs some slight weathering
      so what dose everyone think so far ?
      [ATTACH]88446.IPB[/ATTACH]
      [ATTACH]88447.IPB[/ATTACH]
      [ATTACH]88448.IPB[/ATTACH]
      [ATTACH]88449.IPB[/ATTACH]
      [ATTACH]88450.IPB[/ATTACH]
      [ATTACH]88451.IPB[/ATTACH]
      [ATTACH]88452.IPB[/ATTACH]
      [ATTACH]88453.IPB[/ATTACH]
      [ATTACH]88454.IPB[/ATTACH]
      [ATTACH]88455.IPB[/ATTACH]
      [ATTACH]88456.IPB[/ATTACH]
        This is coming along very nice Moni!! Keep up the good work
        • eddiesolo
          • Jul 2013
          • 11193
          #34
          Late again, apologies Moni. Looking outstanding, love the paintwork and the console looks amazing! Great work.
          Si
          • monica
            • Oct 2013
            • 15169
            #35
            thank you Polux ,Si, glad you like the old girl
              This is looking great moni really unusual.
              • monica
                • Oct 2013
                • 15169
                #37
                ta Ken,glad your liking it, im enjoy making this one,
                oh by the way how much you know about wiring or someone else plz need a bit of help,
                to remove the door switch , and run to the back wall,as i dont wont to fry it,
                as I dont real wont to be taking off the top all the time, to change battery's ,
                and the the spring loaded switch is to strong and the door will not stay open,
                as with the batterys/power is very easy to move,o_O
                so i just need to disable the spring loaded switch to an on/off on ? but how dose one do this,which is the 2 green wires ?
                any help welcome
                [ATTACH]88512.IPB[/ATTACH]
                • Alan 45
                  • Nov 2012
                  • 9833
                  #38
                  I couldn't tell you that moni but seeing that circuit set up has scared me !
                  You don't need to solder all that do you ops:
                  • flyjoe180
                    • Jan 2012
                    • 12400
                    • Joe
                    • Earth
                    #39
                    Looking great Monica, lovely paint work.
                    • monica
                      • Oct 2013
                      • 15169
                      #40
                      hi Alan and Joe,
                      glad you like the old girl, i real dont think im doing much more to her paint wise
                      just need to mess with the switchers and lights,,
                      just 2 little green wises not know which should go were on the switch,ops:
                        Hi Monica lovely start and apologies for just getting on board with this build.
                        Tom
                        • Richi72
                          • Sep 2013
                          • 1100
                          #42
                          Hi Moni,
                          finely found some time to write again, sorry it took so long.
                          nice i mean really nice Dr. Who kit you got there.
                          great start, like the photo background in the Tardis.
                          man I like the whole kit, cant wait to see how it turns out.
                          Cheers Richi
                            I missed this one Moni, but I love what you're doing! Looking forward to seeing some more
                            • monica
                              • Oct 2013
                              • 15169
                              #44
                              hi Tom,no need to apologies, glad you found it, ,
                              hi Richi always glad to see you about as well,and i know gets hard to find time for yourself as well,
                              nice to see you along as well Patrick,o_O
                              glad you all like the old girl so far, not not doing much more to her i kind off like it the way it is ?
                              as Matt callers her sexy,and a bit worn around the edges,
                              I do wont a some type of lights inside but found Leds at 3mm to 5 mm too duel ? or the ones i have,
                              so any ideas most welcome.
                                Hi moni a simple switch usually consists of just one wire, I doesn't matter which one, +or-, the switch just cuts the wire or joins it up depending on the position of the contact in the switch. If the switch is the sort of diamond shaped piece of blue plastic over the round part with a screw each end in the top left of the pic I would say (to check this ) get a short length of wire put one end of it to one each of the wires on the switch to short them out should turn whatever the switch does on. If it does just remove remove those 2 wire and attach them to your new switch.
