MASSIVE X-WING WITH LED'S.
  • eddiesolo
    • Jul 2013
    • 11193
    Well I have started on the big-huge-massive X-Wing.
    Not much but time consuming. I have fitted red LED's into two of the rear engines, one is cockeyed as the chuffing drill slipped , will have to see if I can sort this. Also fitted two bright white LED's into the wing root. The engine fronts have some detailing and a basic wash as have two of the rear engines. The underneath engines I have used some pipework to fill in the void and hide the wiring. The cannons have had white rod inserted to fill the gap and the rear ones have had mesh around them.
    Still loads to do. The LED's have are just a basic wiring loom to check they work before I fully sort it out.
    Si
  • eddiesolo
    • Jul 2013
    • 11193
    Just drilled the top two engines and the same thing happened again, despite a centre punch! They are slightly off centre-getting annoyed.
    Si
      Still looking good tho Si I am sure with your skills you will sort it.
      • Alan 45
        • Nov 2012
        • 9833
        It's looking good mate I'm impressed not as impressed as if it was in a swamp on degobah
        • john i am
          • Apr 2012
          • 4019
          Oooooooooo liking this nice start look forward to more
          • eddiesolo
            • Jul 2013
            • 11193
            I am not listening...therefore 'SHALL...'
            Si
            • Alan 45
              • Nov 2012
              • 9833
              I am not listening...therefore 'SHALL...'Si
              Use the swamp Simon
              • eddiesolo
                • Jul 2013
                • 11193
                "Hmmm, crash not in swamp will you..."
                  Oh boy this is gonna be great!
                    This is cool will be watching.
                    scott
                    • eddiesolo
                      • Jul 2013
                      • 11193
                      Thanks guys.
                      Si
                      • eddiesolo
                        • Jul 2013
                        • 11193
                        UPDATE:
                        All the Led's are in place and the FUBAR of the rear engines has been rectified. The wiring is complete and battery box fitted and all is working. Next stop is finish painting and weathering.
                        Battery box no cover.
                        Battery box with cover.
                        Landing lights on.
                        Rear engines on.
                        Si
                          Great job mate.
                            Awesome!!!!!!!!
                            Even if it is a Rebel ship
                            • takeslousyphotos
                              • Apr 2013
                              • 3900
                              That's "Way Cool" .......... The Force is obviously strong in you Si.
