I'm getting more and more intrigued with this one Peter
....... (The Secret Weapon)
The main cockpit assembly is together, or at least as much as isn't cause a problem with detailing it .............. and I just found and ordered.
1 AGM-130 Air to Surface Missile (That is a really "Bad Boy" ) and AQX-14 Datalink Pod ............... So that's the Ordnance sorted................. I just hope there's going to be room for it all. o_O
Peter
[ATTACH]97792.IPB[/ATTACH]
[ATTACH]97793.IPB[/ATTACH]
Originally posted by \I'm getting more and more intrigued with this one Peter
PeterComment
I now have the Cockpit Assembly and the inner fuselage in Primer ........... So tomorrow I can start painting, and decals.
The Eduard Brassard "GUU-24" Bombs turned up today............. and they are Monsters. I've never used this stuff before and I'm proper impressed with the quality....... So I have a question ????? What is the best Adhesive to use for Resin ???? I thought maybe two part epoxy ??? or is there something better ???
Peter
[ATTACH]97885.IPB[/ATTACH]
[ATTACH]97886.IPB[/ATTACH]
Attached FilesComment
I am planning on Desert Pink........... Maybe digital Camo .......... Or a Straight Line Camo using three shades of the Desert Pink.............. I'm a long way off that yet.
PeterComment
Originally posted by \They do look the biz Peter.As for the glue I'm not sure what's the best I just use CA
PeterComment
Cockpit assembly is very nearly done ............. Paint is finished, more decals than you can "shake a stick at" and most of them the size of a microbe .......... Just a few details to add..........
............ and the pilot is done ......... "Group Captain Screwitt-Upalott" DSO & BAR ........... Not sure if the colours represent too well. Coveralls in Nato Green, Jacket / Lifejacket Field Grey, Boots Nato Black, Gloves Khaki, Visor Metallic Blue over Black ..........
............ I'm on the lookout for a NATO Pilot ...... But until then this guy that came with the kit will do the job.
Peter
[ATTACH]97982.IPB[/ATTACH]
[ATTACH]97983.IPB[/ATTACH]
[ATTACH]97984.IPB[/ATTACH]
It's the control stick ............... When he's seated it rests on the right hand console.
PeterComment
The office is finished ......... Tomorrow night it can go into the fuselage..........
Peter
[ATTACH]98044.IPB[/ATTACH]
[ATTACH]98045.IPB[/ATTACH]
[ATTACH]98046.IPB[/ATTACH]
[ATTACH]98047.IPB[/ATTACH]
[ATTACH]98048.IPB[/ATTACH]
Yes it does ............... I'm proper pleased with the result on this. There is a lot of detail in there. Mostly it's decals loads of the itty bitty tiny little things ...... The only bit I added is the "Pull Handle" or whatever it's called for the ejector seat .......... I figured if we are putting the little fellas in harms way, then he should be giver a fighting chance...................
PeterComment
