Latest work... Windows on upper hull. Lots of pin vice work, snapped the drill 2x but managed to sharpen a new point on it easily enough. You can see the sanded rear bridge section where the PE goes is very thin, in the second photo you can see I put some spare milliput behind it which I will do whenever I make too much. It should give extra strength and light blocking to the area.
[GALLERY=media, 8385]IMAG0809 by dougie posted Jul 12, 2015 at 12:30 PM[/GALLERY][GALLERY=media, 8386]IMAG0810 by dougie posted Jul 12, 2015 at 12:30 PM[/GALLERY]
snap on progress drilling holes' as and when bit doesn't break .cry
Cry literally! I snapped 1 2x I think. I need more now haha, I'll be home tomorrow, see what I can get some on this and Ferrari and lucys rally car but... I've got a baby room to sort and diy stacked up. Bah.
I did a little bit more with windows recently mate but its been sort of side lined with the baby and the wee zero fighter Prototype I'm doing. I will maybe hit it up a bit after that plane is finished before moving on to another car. I was starting a 1/16 car but I may leave that for a bit, not sure, time is a rare commodity at the moment!
Understandable , comitments , I have had set back could be simple wireing hic but board doen;t light up tryed navigation , work fine to battery .
I have another kit on route as to send other back , and ive used bulbs they.wouldnt except .I had some spare cash so have got deluse kit with resin dealta flying added all wires have been shoulderd with discent instructions .all I did will go as experiance and learning curve , you will get there , and look forward too seeing , like me on shelf lit up , james
Cheers James, at least your moving forward. Where did you get your pre built light set?
