Voyager build spayed main body last night
Revell STAR TREK VOYAGER
A pre test of base board and help , on attaching ship to pole ,1/4 wide no thread ? , wires top of pole go into ship need to attach top pole then into ship
Many thanks , blown bulbs nacelles navigation have stripped back to thrusters resholded , personally getting me down .as enterprise bulbs blown sent back for repar so all work on both now back two months patience well thats gone cry
voyager progress plus head ache
attaching model to pole , now cost me bottom belly section luckily back up kit so window being drilled out those sitting in wings watching I hope you don't have as much despair frustration as I have , there is an answer some say give up !! nope to much £ input I wont give it the satisfaction hence nearly bald .
moan aside ,
(it's illogical Jim , its a model the needs of the one out way ,or view of the doubters , even you're self emotion is human fault surpress coz the strength of the mind will survive . ) :S >O.o yep all those feelings arrrrrrrrrrrrrrr
progress away from the other upper hull , fibre optics being feed though windows last count 20 , ? about same to do blue , painting upper hull next few days catch up bottom pole arr rr , delta flyer on table being rubbed down under coat o that is small mag even struggling luckily only me needs a cuppa ha-ha
voyager , progress fiber optic's blue added to windows o going progress respayed rear wasn't happy stand issue still a head ache x
Tell me, are you using a combination of LED's, optic fibre and incandecent bults or just LED's + optic fibre? Just how many are you using, are you making up your own loom or are you using sets? how big is your power supply?
As you may have figured out, I'm looking to use this, but on a 1/24 truck trailer kit with an internal workshop.
I'm trying to gen up on the process and components.
Any guidance will be appreciated.
Keep on trekking!
GavinComment
Hello snow man
This an on going try and error ,LEDs s strips just wasn't bright enough so I bought bulbs both blue white and fiber optic strans which I have put a rubber tube on end of bulb and put strans , into tapering off to hold within model there is room inside , all running at 9volt battery soon electric ,
The battery's soon run down
The base stand has been custom built with power supply added all fiber optics range on eBay £2.98 with poastal all sizes down to the smallest buy these are small heated at the end the expand to fit into windows .i hope this helps more work in next few days enterprise as well crytonComment
hopefully y attached picture ,items will sort my stand head ache nightmare on route U.s hopefully no more added postal charge or import tax :SO.o this covers what feelings have come from this situation arrrrrrrrrrrrrr
Voyager on going fiber optics trimmed melted into windows expanded , more strans
On route
Painting of rear test before decals,added shuttle bay .thank you all for positive feed. Back cry
