REVELL USS Enterprise NCC 1701 - STAR TREK into Darkness - Model Kit 1:500 04882
  • monica
    • Oct 2013
    • 15169
    #16
    very nice add in ,should look great Adrian
      Working aside ,voyager assembled kit maked off leds ,looking at new lighting kit as one I got just lights her up ,more too come plus stands being built US by federation models who have wide range of kits both lighting getting big package too save on cost late 2016 .on this lighting panels both voyager enterprrise display with sound as well .more too come x
        up date and purchase as fellow modellers are now on , I also have added to this build this lighting set to enterprise on route first class
        Contents
        • 35 individual high intensity LED lights in total, comprising: 10 x double-flash white strobes; 9 x blue internal glow lighting; 4 x single-flash white beacons; 9 x white internal glow lighting; 1 x white spot, detailing light; 2 x red internal glow โ€“ impulse engines
        • Pre-programmed micro-controller unit (micro-chip) mounted on a pre-wired, self-contained base board
        • 50cm power connector lead, fitted with a 2.1mm DC socket for connection to a regulated 9V DC mains transformer (not supplied, but available to buy separately)
        • Instruction leaflet - comprehensive instructions guide you through installation in relation to the model build sequence, fully integrated with the Revel instructions and parts.
        • I look forward to starting shortly ,.
        • Adrian "Marvel" Reynolds
          • Apr 2012
          • 3008
          #19
          Hi James,
          As you know I had the same lighting kit as a Christmas gift, they are now fitted to my Enterprise and look amazing.
          Having done mine I would like to advise you of just a couple of things, you will most likely spot those yourself but thought I would say just incase.
          Firstly they are very powerful and light bleed is common, I had primed the interior with grey but this wasn't enough to stop the bleed so I ended up painting around and under the lights with matt black to stop it.
          Secondly, the blue and red lights in the saucer are so strong if you look in through the windows you can clearly see them, so I cut some plastic card and wrapped it around the blue bridge lights and a semi circle around the Impulse red lights.
          I'm sure you won't have any issues is spotting this for yourself
          If anyone is wary of the cost all I can say is it's well worth it.
          My kit is on hold now till I have the spare money to order the Aztec decals, or if my house eventually sells I'll take a trip across and get my own whilst there.
          Adrian
            Thanks
            I will add too project on prep as voyager shows filling around edges were lights shine though presure too have a tight fit causes bulbs too sort out due to space between moulder .
              Kit arrived first class friday , instructions look well cool ,now prep kit and drill holes for light ,matt be adding in inner hull block out any light getting though more still to do voyager took time. Off this week x live @ proper
                Enterprise ,drilled out holes and pre test on positiong ,of lighting , sprayed inner hull ,saucer section matt black.[
                  https://www.facebook.com/james.halse.5/posts/1667115133529105
                  above pictures , off saucer section drilled out and positioned lighting .
                  • Snowman
                    • Oct 2014
                    • 2098
                    #24
                    Looking cool!
                      ] upper section navigation lights , lower also over weekend , feed though to rear section placing holes for underneath hull navigation lights , debating , too mask off or spray before adding lightshttps://www.facebook.com/james.halse.5/videos/1669443686629583/?l=172157366028800013
                        • Apr 2012
                        • 3008
                        #26
                        I used some plastacard to block the red and blue LED light bleed, had a word with Ravenscale at Hinckley and suggested they put that in as an instruction on the sheets they send out, hope they do it for future builders
                        Adrian
                        • Robert1968
                          • Mar 2015
                          • 3596
                          #27
                          How did I miss this one?? Can't be paying enough attention eh
                          Well I'm tagged on now so hopefully I have not missed much.
                          The lighting set should really bring this beauty alive
                          Looking good so far James
                          Kind regards
                          Robert.
                            • Apr 2012
                            • 3008
                            #28
                            Hey don't forget I'm building the same kit with same LED set
                            Adrian
                            • Robert1968
                              • Mar 2015
                              • 3596
                              #29
                              Adrian
                              Oh bugge sorry Adrian ( is it in sci fi builds ? ) I'll ha e to take a look see
                                • Apr 2012
                                • 3008
                                #30
                                Yeah stalled whilst I wait on Aztec masks
