The 'Junkster' Pod Racer
  • tiking
    • Jul 2006
    • 1697
    #31
    29. The Electro cable that will attach to both the pod and the engine. I used a soldering lead thread is what I used to make the big cable. A thinner steel wire is used to wrap around the bigger cable. THese will be painted black then dried brush with silver.
    • tiking
      • Jul 2006
      • 1697
      #32
      0.  The cable attachments. I had the choice of two. The first one and the second version. I choose the second alternative just beacuse of the way it looked.
      Alternative 1.
      Alternative 2.
      Alternative two mounted together and base painted. Will dry brush it before mounting it to the Electro attachments.
      The cable will not be glued as I want  make any changes if I am not 100% satisfied with the look after mounting it. So there are mount holes at each end that will make it possible to just shove the cable in the and out it the need arises. This is one of the main reasons I chose to use lead soldering thread as the cable. It makes it possible to pose the cable exactly the way I want it without any movement.
      • tiking
        • Jul 2006
        • 1697
        #33
        31. I decided use another wire that I found in a dumspters. I simply cut both ends to reveal the copper wire inside. Then I measured the distance between the two Electro attachments and made the cut. I also wrapped a much smaller wire around the the thicker one. I just thought it would add to the overall look.Then I primed the wires with black charcoal paint and then dried brushed them with silver.
        • tiking
          • Jul 2006
          • 1697
          #34
          [COLOR=rgb(0,0,0)]32. And now for the final pics. Still a little more touch up here and there but I think It looks ok. My apologies for the quality of the photos. My camera has a focus issue that needs fixing. I hope you guys like the results:[/COLOR]
          • Snowman
            • Oct 2014
            • 2098
            #35
            Brilliant!! O.o B| :x
            That is one super cool build!!
            • tiking
              • Jul 2006
              • 1697
              #36
              Thanks.
