Industria Mechanika 1/35 Implausible Long-Nose Submersible
    ...so here we go again, the companion sub to my recent Fantastical Fish-Shaped Submersible build, the Industria Mechanika 1/35 Implausible Long-Nose Submersible.
    It will have a similar steampunk style theme to the other sub, but the main body colour will be Brass, with the aim of producing something similar to the picture shown on the box art.
    As usual, the first jobs were cutting off the mould plugs, clean up and applying Mr Surfacer 1200 primer to the interior to highlight any additional flaws that might need further attention.
    This model is supplied with a figure, and I suck at figure painting, so I might leave it out, we'll see :smiling3:
    I'll be watching this one.
      Wow!! You don’t know how I like those kind of model....:smirk::smirk::smirk:
      I will be watching sure!!!!!!
        • 22770
        Nice one Norman I'll be in watching this one too.
        And welcome to the forum.
        • Steve Jones
          • 6615
          Norman
          What a fantastic variety of builds you get on this forum. I looked at the first build and it is awesome. I will be following along mainly to find out how you do those metallic effects. Stunning
          • scottie3158
            • 14201
            • Holbeach
            Norman,
            Will follow this with interest.
            Paul
              • 18901
              Like the look of this, count me in as well...l.
                Thank you all for your kind comments :thumb2:
                I didn't get as much done today as I had wanted too because I spent most of it assembling the photo-etch parts and most of that time was spent on the propeller cowl that proved to be a major PITA :angry:
                In order to build it, you have to roll the flat photo-etch part into a cylinder, wrap and attach the edge detail onto the cylinder and then fit the propeller shaft holder inside. I managed to do this using CA glue, but was unhappy that the cylinder wasn't perfectly cylindrical, but any attempt to adjust it resulted in the CA glue joints pinging open, so I decided to abandon CA glue and solder it together.
                This proved fiddly and time consuming (its not a big part), but at least I now have a part that is as perfectly cylindrical as its going to get, strong and not going to fail and ping open when it feels like it.
                I also began working on the equipment gauges and fitted the side entry hatch, which wasn't as easy as it should have been due to the hatch being slighter smaller than the hole, but I got there in the end
                I think I'm ready to start painting the interior.
                The main photo-etch parts are now assembled and ready to go :smiling2:
                • scottie3158
                  • 14201
                  • Holbeach
                  Norman,
                  Lovely work on the bling.
                  Paul
                    • 18901
                    Hi Norman
                    Nice work on the brass. Looks like electrical solder in the background? If it is, have you tried Carr’s 145 solder and liquid flux? It flows like melted butter and makes life easier as you put less heat in the joint. If I’m wrong, and you have, feel free to tell me to bog off
                    Tim
                      Hi Norman
                      Tim
                      Hi Tim
                      I’m always happy to receive useful advice and I’ll look into getting some of that solder, especially since a lot of photo-etch assembly is on my modelling horizon (I have several more Industria Mechanika kits on their way).
                        • 18901
                        Hi Norman
                        Worth a look at the C & L site for all the Carrs stuff, loads to look at, some of it is even useful . Soldering is much more common in the railway world...I learned from the book “etched loco construction” by Iain Rice. Worth a look if you can get it cheap....uses real world language and keeps it simple so even I could understand it...
                        Tim
                          Hi Norm I'll be follow this with interest, you like Industria Mechanika kits by the look of it as there more on the way :smiling2: .
                          Looks like you may have found a new home as well ?, good luck with the rest of your build.
                          • JR
                            • May 2015
                            • 18273
                            Norm .
                            I'm in , Steampunk Fab . I'll sit with the others and enjoy this .
                            • monica
                              • Oct 2013
                              • 15169
                              what a great,kit,Norman ,I have had my eye on some of these,s for such a long time,
                              and never seen one,like this started and laid out,will be watching :smiling:
                              great start to it.
