Nice paintwork!
Bandai 1/48 Snowspeeder
Great looking office work Chris, Luke and Dak look very nice too.:thumb2:
As I have one too, I'm looking on with great interest.:smiling:Comment
Right then, i'm back in the saddle...(delays due to life getting in the way..lol)
nothing much done, however i did make a schoolboy error.. after painting the inside of the 'maintenance recesses..on the rear cannon sections, i stupidly put them inside my spray booth and turned on a small heater, just to get the paint to flash off.
forgot about them whilst painting something else and discovered the heat had melted one of the 'boxes'.. Noooooooo.
The heat had melted them to such an extent that they were in 'drooping' and no longer fit the area ...
sooo, a couple of hours of hacking, filling and sanding and i managed to get it back into a close enough shape for me to carry on without scrapping the whole build..Comment
Nice save Chris. Glad to see you have had the opportunity to get back to the bench with this oneComment
Update Time...
well she's had a quick jaunt into the paint shop...
first off... Black Basing. this helps give underlying shade to the base coat..
[ATTACH]312402[/ATTACH]
and after a couple of hours it was onto the Base Coat...
Which i'd like to add shouldn't be a point to stress over,
There are a billion and one different ideas on the Interweb as to which colours and tonal variations Lucasfilm Ltd used when constructing the original studio models,
And granted that the original paint they used is no longer available..(highly poisonous),
Most folk mix up something that is 'fairly close' to how the Studio Models looked....(If you take into consideration the use of studio lighting and even the quality of the colour film stock that was used, no two images of the subject look the same..),
So with that in mind i mixed my own colour up, this was a mix of Tamiya XF-2 , XF-55 and a odd drop of XF-20...
XF-2 (Flat White) 3 Parts,
XF-55..(Deck Tan) 1 Part,
XF-20 (Medium Grey) 1 part
This was thinned to a 'cheeky' 50/50 mix and then lightly Ghosted or misted onto the black base at around 10 to 15 psi.
[ATTACH]312403[/ATTACH]
[ATTACH]312404[/ATTACH]
[ATTACH]312405[/ATTACH]
Leave this overnight to harden off, and then onto a bit of extra panel work,
For the various panels I painted them with varying tones of the base coat..(just added a bit of White or a bit more Deck Tan to suit how I was feeling, I figure that when painting, if it looks ok then it can't be far wrong...
And also remember, there are no hard and fast rules about just which panels should be a different colour, (even during filming the crew used the same models to replicate different ships....they just added various colour changes to existing models), So my advice is to just have fun with it...
[ATTACH]312406[/ATTACH]
[ATTACH]312407[/ATTACH]
Now although this might look a little 'bright and clean', by the time I've finished the weathering the original base coat colour will change completely... see my 'X-wing build' for further proof ....lol
hope you like it so far..Comment
Starting to crack on with this now...
Grey Panels added to the 'engine / gun' sections.
[ATTACH]312586[/ATTACH]
[ATTACH]312587[/ATTACH]
Also started the Chipping on the bottom..
but can't make my mind up... personally i think I've gone a little bit overkill... what do you think folks.??
[ATTACH]312588[/ATTACH]Comment
