Looking great.
Post Apocalypse "Road Train" kitbash.
Thanks EJ.
I started today by smoothing off the underside. There were lots of ribs, and swivel points for the bogies that looked out of place, so I ground them down as much as I could (and ended up with lots of holes!), added some offcuts of card as packing pieces, then thin card. This now gives me a nice flat surface to add ribs & rails back in, but in the right place this time.
[ATTACH]391263[/ATTACH]
I then made a start on the trailer. It's going to be a drawbar type, with swivelling front bogie, about 2/3 the length of the main rig. The main part of its chassis was made up from Maquett I-beam, doing my best to keep it square & true, then I dived into the bogie. Framework was again made with (smaller) I-beam and the inverted leaf springs were made by laminating 2 x 0.5mm strip.
[ATTACH]391264[/ATTACH]
The underside looks a bit messy as I've used CA on the (brown) torque rods to add strength. Technically these should have swivels at either end but I haven't yet developed the Simon/Scottie/Steve superhuman powers needed for that kind of detail :smiling5:
A bit of crud should disguise it well enough later down the line.
[ATTACH]391265[/ATTACH]
And in place on the chassis with wheels added temporarily on a rod running through the axle tube. Now that I have the height I can work on the rear suspension tomorrow and add the towing A frame to the bogie.
[ATTACH]391266[/ATTACH]Comment
Andy - I'm late to this one, but what a great project, looks fun and challenging at the same time.
PeterComment
Cheers Steve, glad you're liking it so far.
I got the rear axle done today. Here it is with the wonky wheels held on with blutack. At least they all touch the ground lol
[ATTACH]391367[/ATTACH]
And without the wheels
[ATTACH]391368[/ATTACH]
I dug this out of the bottom drawer of my PC desk. I used to use it for chopping photo's up but it does a great job on thin plasticard.
[ATTACH]391369[/ATTACH]
Using that, cutting a square deck for the chassis was easy. I edged it in C section, added the towing frame at the front, and put on a few rivet & rib details
[ATTACH]391370[/ATTACH]
I've also made a start on a fuel bowser for it. I'm not sure how uniform I'm going to get the shape so it might end up covered in stuff to disguise that! :smiling5:
[ATTACH]391371[/ATTACH]Comment
Looking mighty fine. If you pin/bush the bogies you could get some articulation if placed on rough ground or have you? The chopper was a great find. Don't forget, what ever was not ready-to-hand was rough cutnfit fabricated by non-pros, likely w/o proper tools:smiling3:. PaulEComment
Lovely work I was thinking of getting one of those paper cutters now I think I will look again.Comment
Thanks Dave. I'm coming up to the tricky bits where I need to get creative and start adding the bodged up additions. Imagination is not my strong point, but hopefully something will come to me.
Thanks mate. I saw the cutters mentioned somewhere and remembered I'd still got one. It works a treat.Comment
