SimonT - "Does my bum look big in this?" A wee lass in an armoured battle suit
  • SimonT
    • 2824
    Came across this on one of my late night ebay perambulations and thought it looked quite good fun
    Small lass in a large mechanised, armoured and armed, battle suit
    Judging by the fine surface lines that are evident in places it looks to have been at least partially 3d printed but then cast in resin as per normal as there are quite a few tricky mould lines to remove
    I have done all the basic cleanup but need to go around again to see if I can spot any more of the fine mould lines
    I have re-scribed some of the panel lines and opened out some of the recesses and holes that were shallow to aid casting, including drilling out the gun barrels
    I also plan to add some extra hoses and cockpit detail
    Not happy with the solid canopy and how it sat inside the edges of the cockpit so, after a lot of scribing, the 2mm thick canopy was released from the framing. The frame will get some additions so that it sits on the edge of the cockpit rather than inside it
  • rtfoe
    • 9082
    Hi Simon, is this a MAC kit?
    • SimonT
      • 2824
      Hi Richard - by YuFan3D, the same place as the wabbit
        • 15687
        Morning Simon
        That is unusual. Not quite as mad a Wabbit but certainly up there as "and now for something completely different"
        • KarlW
          • Jul 2020
          • 1522
          I keep hovering over Buy-it-now on this, but the last kit I ordered from this seller didn't arrive so, the post has been pretty good but I've had a lot more INR claims on eBay since this pandemic thing started.
          • SimonT
            • 2824
            Morning Jim - I agree, not quite so bonkers as wabbit but it looks like it should be fun to paint
            Hi Karl - took about a month to arrive. One piece snapped in the post but a bit of CA and filler soon fixed it. With the ebay/PayPal buyer protection in place these days it isn’t too much of a risk - I’ve had a couple of no shows but have received full refunds
            • rtfoe
              • 9082
              Thanks Simon for the clarification.
              • SimonT
                • 2824
                sanded off a few more mould lines then did some test assembly with white tack to get it standing up
                once it was standing I marked the limbs in relation to their position on the body, removed the tack and CA'd them in place
                I then flooded the ball joints with liquid CA
                a few general shots
ID:	1131452Click image for larger version
                started working on widening the canopy frame
                for anyone wondering it stands 80mm tall
                it was listed as 1:18 but that would make the wee lass very wee at about 2ft tall and the suit at just under 1.5m
                using her height, 35mm, and average female height it works out at a more credible 1:45
                that would make the suit 3.6m which is a bit more impressive
                it might be fun to scratch one in a standard scale - 1:35, 1:24, 1:15 :thinking:
                • Steve Jones
                  • 6615
                  Well that went together well Mr T! This one should look really nice painted up. Going to be using metallic paints or keeping it all matt??
                    • 18901
                    Interesting build, looks to fit quite well.
                    I came across this and thought of Your build for some reason...l
                    • SimonT
                      • 2824
                      Not many parts Steve plus it has been on the go in the background for a couple of weeks cleaning up
                      Going for the matt well worn and abused look :thumb2:
                      Tim - that is just bizarre. An early prototype perhaps :thinking:
                      modified canopy frame tidied up and mounted - drilled and pinned it to make the joint stronger and allow me to bend the wire into position to suit the figure before gluing in place
ID:	1131506added a couple of extra conduits each side, because I could
                      that's the great thing with sci-fi of this kind, it doesn't exist so can't really be wrong
                      going to add a few more bits here and there then I will have to tackle moulding the canopy
                      • rtfoe
                        • 9082
                        Simon, I'd like to see you mould the canopy as I have one or two canopies that need moulding after they turned yellow.
                        • SimonT
                          • 2824
                          Hi Richard - going to try plug moulding it using the resin bit that I cut out. Have had some limited success in the past with this method. Resin will need a little tidying up before I give it a try
                            So it’s somewhere around standard SF wargames size? Would make sense for a subject like this, I think. Odd that they advertise it as 1:18, though.
                            [ATTACH=CONFIG]n1131489[/ATTACH]
                            That looks like a more primitive version of this, that I came across last night:
                            • KarlW
                              • Jul 2020
                              • 1522
                              Thanks for providing dimensions, I couldn't wrap my head around it on the listing page, seems they measured the mech and used it's 80mm height as a man height and worked from there, if the pilot was 80mm then 1/18 would be about right.
                              Unless she's meant to be a faerie, has she got pointy ears?
