I’d put it on the inside, I think. That will give more of a feeling of thickness, I’m guessing
Macross - Destroid Defender 1/72
I don’t suppose you can glue in the windows either way round? If so, you could experiment with one to see which looks better.Comment
Attached FilesComment
That’s what I was kind of hoping they wouldn’t haveLooks like you’ll just have to choose one or the other and run with it?
Hi Gavin
I'm not into this genre but they do look fun. I know Steve enjoyed his foray into sci-fi. Despite the fit issues you have got it together nicely. Great idea to display with the armoured car for scale. I look forward to the painting/weathering. Great scope there and hopefully the book will give you some ideas.
JimComment
Hi Gavin
Anyway, we move on to a spot of pre-shading.
This will hopefully allow me to add a bet of depth to the paint job.
Thanks for looking!Attached FilesComment
It was a bit warmer today, no hard frost on the ground, so I ventured out to the garage and did a bit more painting and assembly.
I think the kits are starting to come together quite nicely. Did a 50/50 smoke and clear green treatment on the inside of the windows and I quite like what I see.
The only problem with super close ups, there is no hiding any blemishes, but a distance the effect looks more believable.
Anyway, things are getting together and are looking pretty good.
Thanks for looking!Comment
That’s looking very good so far
Quick question: how tall is the model? I have Bandai’s 1:100 Warhammer Attack Tomahawk, but I suppose this model would be a fair amount larger than that, so posing them together won’t work?Comment
On the flipside, you could do a perspective diorama with the smaller kit in the "distant" back ground?Comment
I could, except I won’t be building a diorama with itI intend to build the model I have as a BattleTech WHM-3R Warhammer by means of nothing more than a paint job as this particular one:
[ATTACH]441927[/ATTACH]
If the Destroid Defender were about the same size, I could call it an RFL-3N Rifleman and pose the two together, but alasComment
