1/72 Millennium Falcon
  • Bri62
    • Jan 2023
    • 1890
    • Brian
    • Widnes Cheshire
    #46
    This took me over an hour lol
ID:	1197565Click image for larger version
    • Gern
      • 9226
      #47
      Looking real good Bri. I've got some of the Bandai Star Wars kits (not this one alas) and I'm extremely impressed with the amount of detail in the mouldings.
      You probably already know, but some of the Bandai kits react really badly to enamel paints. I watched Phil Flory build an AT-ST some time ago, and the plastic literally crumbled into pieces.
      • Bri62
        • Jan 2023
        • 1890
        • Brian
        • Widnes Cheshire
        #48
        Thanks for the heads up no I didn't know but I only use acrylic paints
        • Bri62
          • Jan 2023
          • 1890
          • Brian
          • Widnes Cheshire
          #49
          More progress the detail in this kit keeps impressing me.
ID:	1197603Click image for larger version
          But those pipes are very very delicate.
            • 18271
            Originally posted by boatman
            YES Bri i think R2D2 was on the ship AS HE HAD princess leia message about the death star to get to the rebels
            chrisb
            But as he cant be in the cockpit, and the rest of the inside cant be seen.... But as Jakko wrote, easy enough to make a rudimentary R2 in that scale out of the sprues.
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #51
              yes point taken Ian an nice work Bri
              chrisb
              • Waspie
                • Mar 2023
                • 3488
                • Doug
                • Fraggle Rock
                #52
                Easy for you to say!!
                • Bri62
                  • Jan 2023
                  • 1890
                  • Brian
                  • Widnes Cheshire
                  #53
                  Finished the mandibles.
ID:	1197606Click image for larger version
                  I must say this kit is addictive I woke at 3am and couldn't get back to sleep thinking about the falcon so I got up and did a bit......knackerd now though
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #54
                    [ATTACH=CONFIG]n1197606[/ATTACH][ATTACH=CONFIG]n1197607[/ATTACH]
                    LIKE ME Bri as if i had a problem on my big Tiger i was somtimes up at 3 am as could not sleep with the problem goin through my mind so the only answer is to get up an have a go at the model an yes i felt shattered later in the day after such an early get up an start but it made me happy if i solved the problem
                    chrisb
                    • Bri62
                      • Jan 2023
                      • 1890
                      • Brian
                      • Widnes Cheshire
                      #55
                      There is no way you could put this together without glue I know it's supposed to snap together but some of the bits are real loose and others have gaps, I'm gluing everything with Tamiya extra thin
                      • Bri62
                        • Jan 2023
                        • 1890
                        • Brian
                        • Widnes Cheshire
                        #56
ID:	1197614Click image for larger version
ID:	1197615Click image for larger version
ID:	1197616Click image for larger version
                        Primer has to dry
                          • 18271
                          Coming along nice. Quick as well was it 6 parsec. he did the run. (parsec is a measure of distance not time, by the way so the dropped the ball on that one).
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #58
                            anyone know HOW FAR A PARSEC IS as its a distance greater than a light year
                            i know that
                            chrisb
                            • Gern
                              • 9226
                              #59
                              A parsec is 3.26 light years - the distance light travels in a year.
                              In miles, that's roughly 3.26 x 6 000 000 000 000 = 19 560 000 000 000 miles
                              You don't want to be going that far to pick up that paint colour you forgot!
                              • Mark1
                                • Apr 2021
                                • 4156
                                #60
                                i know that
                                chrisb
                                3.086 × 1016 metres
                                Formula for an approximate result, multiply the length value by 3.086e+16
                                Apparently .
