JMC Mining Ship the "Red Dwarf"
    Thanks Si
    Just a little picture update ... i've added more detailing and the superstructures (roughly)
    Just needs a little clean up around the edges.
    [ATTACH]68040.IPB[/ATTACH]
    [ATTACH]68041.IPB[/ATTACH]
    [ATTACH]68042.IPB[/ATTACH]
    [ATTACH]68043.IPB[/ATTACH]
    Gave it a coat of paint just to see if it all looked in proportion
    [ATTACH]68044.IPB[/ATTACH]
    [ATTACH]68045.IPB[/ATTACH]
    • Gern
      • 9213
      #32
      Originally posted by \
      Its not as stiff as pizza bases Dave, but it would make up into a building shape quite easily, probably more suited to 1:72 scale though , you can etch it to a certain extent with a scalpel too so brick work wouldn't be a problem
      You're right Col. I think it would need to be stiffened to use as walls etc. except on smaller structures but as facings (such as on Ron's dock scene) it looks very useable. Cheap too!
      Gern
      • Andy2035
        • Aug 2011
        • 730
        #33
        I'm really trying to hold back the slobber Sir...
          heh heh ... thanks Andy
          Few more update piccies to show the extra detailing thats going on, and there's quite a lot to do to get it looking right as to how i picture it in my head.
          Foam, card, boggly eyes, electrical components, drawing pins and bits of wire slapped on.
          [ATTACH]68170.IPB[/ATTACH]
          [ATTACH]68171.IPB[/ATTACH]
          [ATTACH]68172.IPB[/ATTACH]
          Another quick coat of paint
          It helps to see where it needs more detailing and the paint layers help to stiffen and coat the card and foam even more ready for washes and weathering.
          [ATTACH]68173.IPB[/ATTACH]
          [ATTACH]68174.IPB[/ATTACH]
          few close ups.... start of the pipework and the cutout with detailing
          [ATTACH]68175.IPB[/ATTACH]
          [ATTACH]68176.IPB[/ATTACH]
          [ATTACH]68177.IPB[/ATTACH]
            Just keeps getting better Colin!
              • 22770
              #36
              Boy does it keep getting better. Great work Colin
                Thanks guys,
                Bit more progress....
                Got a bit more done on the asteroid strike, adding some texture to the large "rock" and adding some smaller asteroids that have embedded themselves in the hull also.
                [ATTACH]68307.IPB[/ATTACH]
                Started the rear of the "recessed" section, there's lots of small item detailing in this part so will take a while
                [ATTACH]68308.IPB[/ATTACH]
                Made the "Scoop assembly" for the front of the ship (basically balsa, wire and some stick on jewels)
                [ATTACH]68309.IPB[/ATTACH]
                [ATTACH]68310.IPB[/ATTACH]
                [ATTACH]68311.IPB[/ATTACH]
                [ATTACH]68312.IPB[/ATTACH]
                • colin m
                  • 8741
                  • Colin
                  • Stafford, UK
                  #38
                  Brilliant - as I flick through the posts, I just keep getting the theme tune running through my head.
                    Fantastic and brillant work so far!!
                    Have fun!
                    • peterairfix
                      • Jul 2012
                      • 11074
                      #40
                      I think the line by kryten goes"well spin my nipple nuts and send me to alaska" it's looking A1 so far.
                        Got all the relevant detailing on and have stuck the "scoop" on the front so it can be sprayed/weathered together .. (im bound to knock it off or snap something so watch this space)
                        Anyway here's what it looks like before .......
                        [ATTACH]68561.IPB[/ATTACH]
                        [ATTACH]68562.IPB[/ATTACH]
                        [ATTACH]68563.IPB[/ATTACH]
                        [ATTACH]68564.IPB[/ATTACH]
                        And after spraying .(have given the centre recces a graphite grey coat then over-shot with the oxide to give a little more depth)
                        [ATTACH]68565.IPB[/ATTACH]
                        [ATTACH]68566.IPB[/ATTACH]
                        [ATTACH]68567.IPB[/ATTACH]
                        Now for the washes, pastels and dry-brushing ... oh woe is me
                          So its finished, as far as i'm concerned anyway (i was just starting to have enough)
                          Used a "mistake" that more than a few of us have made in the past by mixing acrylics and celulose together to get a "crazypave" type finish ... normally when you try and reproduce a mistake it doesn't work but this time it worked on all the facets without fail. I think it looks quite "space ragged" overall, and not knowing exactly what space would do to a painted finish ... this will have to do
                          Used powdered pastels to fill in some detail and then drybrushed silver, brown and black to highlight the raised detail.
                          [ATTACH]68694.IPB[/ATTACH]
                          [ATTACH]68695.IPB[/ATTACH]
                          [ATTACH]68696.IPB[/ATTACH]
                          [ATTACH]68697.IPB[/ATTACH]
                          [ATTACH]68698.IPB[/ATTACH]
                          [ATTACH]68699.IPB[/ATTACH]
                          [ATTACH]68700.IPB[/ATTACH]
                          [ATTACH]68701.IPB[/ATTACH]
                          [ATTACH]68702.IPB[/ATTACH]
                          [ATTACH]68703.IPB[/ATTACH]
                          [ATTACH]68704.IPB[/ATTACH]
                          [ATTACH]68705.IPB[/ATTACH]
                          [ATTACH]68706.IPB[/ATTACH]
                          [ATTACH]68707.IPB[/ATTACH]
                          Thanks for watching
                          Smoke me a kipper.. i'll be back for breakfast
                            Hi colin and WOW that is very very cool i like it what a cracker.
                            scott
                            • spanner570
                              • 15391
                              #44
                              Magic stuff Colin....just look at all the bits!
                              • Alan 45
                                • Nov 2012
                                • 9833
                                #45
                                Absolutely fantastic Colin. I was expecting starbug to appear at any moment.
