Hi everyone!
I apologize for the long intervals between updates, but for October all I did was a lot of drilling and aligning and drilling and aligning and..... well, you get the point. So, I thought I would wait an extra month so you can at least see some progress with the dock.
Because using metal in model construction is not a forgiving as with plastics, one has to be more precise with the drilling and bending of tubing and other pieces, so yes, it does take a little longer to get things done, but I'll tell you, in this case at least it will be worth the wait.
In this month's update I've finally been able to test fit some of the panel frames with the main modules. As I said In other updates I needed to wait for some parts to come that were back ordered. The back ordering occurs because of the quantity of items that I need for these projects. I've had to order 164 copper tubes, about 56 or so threaded rods and a couple hundred dome and regular nuts and so forth. I've had to cut a lot of these items to length and make sure they fir properly into their respective pieces. This is definitely a take-your-time and do-it-right-the-first-time projects(s).
Other than the panels frames, there will be very little to solder together. Following the design of ST:TMP filming miniature there will be a lot of screws, nuts and bolts holding this baby together. If you watch all of the drydock scenes including the Enterprise leaves drydock you will see a lot of these details right on the screen.
But anyway, this isn't a just drill it and put it together project. This updates I've started by adding the anchor cone pieces to the outside parts of the overhead module, then I have to take each panel frame individually make sure that each of the holes both on the module side as well as on the side and bottom frames will line up. I've started on the top tier of frames on only one of the module pieces. Now that I know what to do I can get the other tiers lined up and in place. With all of the threaded rods and dome nuts in place I was very pleased to find that the panel frames are able to support their own weight so when all of the pieces are finally in place I will not need additional supporting rods to hold everything up as I did with the 1/350 PLE drydock. This is also something that TMP dock was able to do.
All the pics in this month's update are pretty much test-fitting pictures to make sure everything lines up correctly. I will not be able to permanently weld everything together until I can get the wiring in place for the light panels and other effects. There are 19 new pics in the November Updates tab.
By next update I hope to have the tiers finished on at least one of the modules. We'll see how it goes. I will try to get as much done as possible in the next month because December is a very bad month for me secular jobwise, so I hope you enjoy the new progress pics and hope to hear from you. All comments positive and negative are welcome!
For those of you visiting for the first time, please sign up as a member and be the first to receive notice of any updates on my site.
Talk to you next month! Take care and Happy Modeling!
Mark
[ATTACH]72143.IPB[/ATTACH]
Mark
