Starting kit !!!
    Starting kit !!!
    Hi, I'm new at this world, in your opinion which kit would be the best option for a newbie ?
    My areas of interest are: Sci- Fi, airplanes, WWII, cars.
    I have been looking but I have no perception of the level of difficulty on most kits, so suggestions are welcome.
    Thanks for the time spent with this.
    Hi there and welcome the friendliest forum ever, can you tell us what scale you had in mind? For Sci fi might I suggeSt warhammer 40k vehicle kits I've just started building these so I can tell you they are most excellent. I might also suggest armour kits in 1/35 scale cars and air craft are not really my cup of tea you mIghtfield need to ask some of the others guys and gals for that.
    scott
    • Alan 45
      • Nov 2012
      • 9833
      Welcome to the forum Joaguim , there are a range of airfix starter kits available in tanks aircraft and cars and quite reasonably priced , sci-fi can be exspencive for quite easy kits but revells range of Battlestar Galactica kits are nice easy and quite affordable be sure to get the Revell kits and not mobeus kits , there are the same kits but revell is cheeper
        Thanks for the input guys, this is really a friendly forum, I'll keep you guys posted on my progress.
        Thanks you very much Alan & Scott.
        • takeslousyphotos
          • Apr 2013
          • 3900
          I agree with Alan ........ I'm just starting on the Revell Viper MKII ....... That'd be a good start for you. Not too many parts and painting for the standard livery will be a breeze ....... I picked mine up for £ 18.99 on evilbay.......
          Peter
            Are there any differences between the Revell and Moebius version ?
            Where would be the best place to know the paint color codes needed ?
            Thanks for your time guys.
            • Alan 45
              • Nov 2012
              • 9833
              Originally posted by \
              Are there any differences between the Revell and Moebius version ?Where would be the best place to know the paint color codes needed ?
              There is no difference in the model at all , revell do what's called a rebox and charge £10 less than mobeus for the same kit and the paint numbers are in the instructions so you will know which ones to buy
              • takeslousyphotos
                • Apr 2013
                • 3900
                The Moebus and Revell kits are identical ......... Same Mould. The Revel Kits tend to be cheaper........... and I've heard that the Moebus kit doesn't come with the pilot figure (although I can't confirm that) ........ I don't know if you ever buy from "evilbay" but item 131403537013 is a good buy at £ 18.99 post free
                Peter
                  Thanks guys, what about the best place to find out the right materials for each kit ?
                  Thanks.
                  • takeslousyphotos
                    • Apr 2013
                    • 3900
                    Thanks guys, what about the best place to find out the right materials for each kit ?Thanks.
                    The full Revell paint list is ................
                    White Semis Gloss
                    Aluminium Metallic
                    Grey Semi Gloss
                    Black Semi Gloss
                    Clear Gloss
                    Steel Metallic
                    Red Clear
                    Silver Metallic
                    Matt Black
                    Gloss Black
                    Gold Metallic
                    Olive Green
                    Brown Semi Gloss
                    Copper Metallic
                    Purple Red Semi Gloss
                    Fire Red Semi Gloss
                    You don't necessarily have to use Revell paint ........... Humbrol or Tamiya do equivalents......... Have a word with John in the shop........ He'll sort you out with the right stuff............. http://www.scalemodelshop.co.uk/
                    Peter
                    [ATTACH]97919.IPB[/ATTACH]
                      That is perfect, thanks for the time spent with these issues.
                      • takeslousyphotos
                        • Apr 2013
                        • 3900
                        No problem buddy .............. Glad to be of help.
                        Peter
                          If you're really really new, I would highly recommend keeping it simple and get a Spitfire Starter kit: http://www.airfix.com/shop/spitfire/supermarine-spitfire-mkia-starter-set-1-72.html
                          And follow the YouTube video:
                          You can get a decent model out of it (the paints it comes with are a PIA, but follow the instructions and you'll get there). If at the end you decided it's too much faff, you've only spent £7!!
                            Fantastic Mike, thanks to all of you, will come back when have my first one ready, you guys rock.
                            • Paul Davies
                              • Apr 2014
                              • 284
                              Airfix kits are good starting point. For cars you can not beat Tamiya. Tamiya kits fall together and the instructions are always spot on
