Help Neep; Robby the robot ;LED,s
  • monica
    • Oct 2013
    • 15169
    Ok,I,m after some help with LED,s and Fiber optic,s for my 1/12 Robby,
    1st of all someone hear did give a link to a chap who is very helpful,but I lost it,ops:
    at the very top there is a yellow flashing one,can be from 3mm to 5mm,
    2x what im calling his ears,are blue,one,
    which will need to be ran in fibre optic,as there a sharp bend,2mm or 3mm
    bottom of his heahd is a bank of 4 red flashing ones that also need to be ran off F/O,
    In 2mm or 3mm,
    for his chest,will need 2 or 3 ,5mm or 3mm one,s
    2x white just below the blue in his chest for the controls,
    so if anyone is able to help me a little with the DIY,, I have in mind would be greatly appreciated
    I did see this kit,
    http://www.starling-tech.com/index1.php?id=robby
    but I don't have US $113,oo which is AUD $ 154,oo ops:
    would be cool as he dose talk as well,but to put in a $22.oo kit ,Im not that mad lol
    or yet,
    [ATTACH]115965.IPB[/ATTACH]
  • takeslousyphotos
    • Apr 2013
    • 3900
    Monica,
    Try these people ........... http://au.rs-online.com/web/c/displays-optoelectronics/leds-led-accessories/visible-leds/?sra=p&r=t
    I buy loads of stuff from them here in UK for our workshops.
    • eddiesolo
      • Jul 2013
      • 11193
      Fibre optics are not the best for bending, trust me I busted loads doing the lighting for that 1/24 Huey. Heating gently can work...but, too much it shrivels, too little it can kink and you get no light from the end.
      Best thing to do is get either a wiring loom made up that incorporates all you need with plenty of wiring, you could always snip down and connect all to connector block inside the body.
      Si
      • monica
        • Oct 2013
        • 15169
        ta Peter,Si,for helping,
        will have a look at that and see if i can make some sense of it all,
        can you heat the F/O in hot or worm water to be able to bent it ?
        can the F/O be cut to what length that you need ?
        or how close dose the resister need to be to the LED ?
        that's what i was thinking of doing with the loom,then just the 2 wires out to switch and power,
        its only the ears that are the hard part because they have 90/o bends in them,
        the rest is all straight runs,
        • eddiesolo
          • Jul 2013
          • 11193
          The resistor can be anywhere on the wire IIRC.
          Not tried hot water to bend, defo worth a try Moni.
          And yes, you can cut F/O down to any length.
          I wired all up to a common connector, this was then wired to a simple on/off switch that incorporated the batteries-made life a lot easier.
          • Adrian "Marvel" Reynolds
            • Apr 2012
            • 3008
            Monica try
            WWW.captainjacksmodels.co.uk
            I use him for all my optics now he's a great guy and will build any combination you want
            Adrian
            • monica
              • Oct 2013
              • 15169
              ta Si,
              will start to get things,
              need wire as well,so some think like a 20g or 22g should be fine ii think,
              and holders for the LED,and F/O,
              • monica
                • Oct 2013
                • 15169
                Originally posted by \
                Monica try
                Adrian
                ta Adrian,I think it was you who said that before to me and I,lost the link,
                will give him a try as well as the one Peter said,
                • eddiesolo
                  • Jul 2013
                  • 11193
                  Monica try
                  Adrian
                  Snap, I use the same guy Ade...top service, will make you anything up to any size.
                  • monica
                    • Oct 2013
                    • 15169
                    cool well shell send him an email,stating what I,m after and see how much,
