[ATTACH]68418.IPB[/ATTACH]
[ATTACH]68419.IPB[/ATTACH]
[ATTACH]68420.IPB[/ATTACH]
[ATTACH]68421.IPB[/ATTACH]
[ATTACH]68422.IPB[/ATTACH]
[ATTACH]68423.IPB[/ATTACH]
[ATTACH]68424.IPB[/ATTACH]
[ATTACH]68425.IPB[/ATTACH]
[ATTACH]68426.IPB[/ATTACH]
[ATTACH]68427.IPB[/ATTACH]
Here is the second of three mini dioramas...At sea.
I've tried to depict a rough sea with the lifeboat ploughing through the waves, heading out to the casualty.
I used the same method with these pictures as I did with my J.F. Kennedy's PT109 dio....Simply tilted the base to the sky and let the light do the rest! No fiddling with after. What you see is untouched.
Here's a tip...When taking photos outside, never think the photos look o.k. I did, only to discover 3/4 of them had power cables which run across the field behind us, showing up behind the lifeboat, prat!
So here are the pictures. Too many, but I hope you like them.....
Ron
Don't know why the pictures have appeared before the description, I must have pressed a wrong button!
Ron
