In an upcoming group build, I am thinking of doing an Airfix Ship, (HMS Fearless) and also thinking about a small diorama.
So I will need to have water (or rather something that looks like water) in the diorama.
Having never done "water" before, what would be your recommended method for a beginner?
Not looking for anything too expensive or too complicated, and not after the perfect finish, just something that approximates water to give the ship some life.
My initial thoughts are to use foam board as the base, cut small wiggly lines diagonally across the top of the base, to give a "wave" effect.
NB: the ship would be placed diagonally on the board as though it were sailing diagonally across the base.
Obviously cut out the shape of the hull in the base so that the ships hull is lower and is at the correct level.
Then paint the base some sort of blue/green to imitate the sea.
Then highlight the top of the waves with some sort of white substance/paint, etc to recreate "froth".
Not sure how to do bow waves where the ship is cutting through the water, and wakes to the rear, maybe something like PVA built up?
Any advice welcomed, cheers
