Revell U.S.S. forrestal
    lol the real thing 256 metres long!!!!
      this is what i have done on the ship so far. feel free to comment.
        That looks like the old airfix kit (has it got vigilantes in it?)
          im not sure what you mean by vigilantes. can you explain? sorry
            aircraft type!!! :-)
              a tip i got of nigel....the deck looks quite shiney. Give it a sand down with a fine grade wet and dry paper, give it a wash, wait for it to try. This way the paint will adhere to it alot easier!!
                yes Nigel the kit came with some aircraft, 16 in all. i did a search on google and it seems to be a common kit being produced by a few different brands (airfix,revell,italeri)
                and Richard i have not yet done anything to the deck yet, but i will sand it down like you said. is 1000 grit good enough?
                  im not sure, have to ask nigel on that, i use 1200c!
                    Any wet or dry would do the job. The important thing is that you do not use a grade that will leave marks after it is painted and that depends on the paint and method of application..
                    I think you should get away with 1000 but I would do a quick test peice on say the underside of the deck. If you can see scratch marks then you need a finer grade.
                      i think that i have some 1200 laying around.
                        if you use 1000 make sure you use plenty of soapy water as well
                          thanks for the tip Nigel.
                            can anyone recomend a color to paint the "grey" part of the ship and another grey that would look good as the flight deck color, i think that it should be darker.
                            thanks
                              probably ghost grey for the ship and medium sea grey for the deck ??? but a few of the ship moddellers may be able to give you a more definitive choice
                                goast grey is nice...if your using humbrol enamels the do a US Goast grey erm... no. 127 and maybe us medium grey no.126
