Battleship grey ( airbrush )
  • Robert1968
    • Mar 2015
    • 3596
    I'm starting to think of spraying my firsgvlight coats of colour on my Hms Rodney 1/700
    I use Acrylic paints Vallejo and model air mainly with tamiya from time to time.
    Does anyone know the best closest match to No 507 admiralty grey ??
    I think it's dark sea grey 71.041 but I'm not sure so advice and help greatfully appreciated
    Regards
    Robert
    • 18266
    I have the colour coat paints and a Vallejo model Colorado paint chip book. That's the actual paints hand painted on the page and not a colour litho.
    Anyway. The closest I could get things, (in daylight balanced light) are these:
    AP507a Vallejo model Color field blue #964
    AP507b. Vallejo French mirage blue #900
    AP507c Vallejo green grey #971
    In the scale you are doing, you might want to lighten them a bit. Also the Vallejo green grey might need a tiny bit of white and a dot of blue.
    • Robert1968
      • Mar 2015
      • 3596
      Thanks Ian ( I have 964 and I have white in Color and model air so I'll do some experimenting.
      By the way I do like your hood website ref as it spoke highly on errors of " guesstimation of colour ref from b/w photos etc
      Glad we have a good ref back up
      Thanks
      Robert
        • 18266
        If and its a very large IF I ever build another Battleship I will most likely go for the Vallejo as well. As much as I like the Colour coats paint, up to four weeks delivery is naff. But what can you do when you have started to paint it!
        • Robert1968
          • Mar 2015
          • 3596
          Wel Ian the reason I went to Vallejo and model colour is I find they have a lot of varying colours and they mix well with water or Vallejo thinners. I was finding buying a lot of other paints no matter what you clean the a/b with they seemed to get clogged and even deep cleans would weaken the seals ( in my opinion ) I have very few problems if any now.
          I have had more expensive A/b in the past so maybe I should just stick to John at SMS cheaper A/b offers
          Regards
          Robert
            • 18266
            I use Vallejo most of the time but am a bit CDO (like ODC just in the right order :-) ) When it comes to boats and aircraft.
            A word of warning about thinning them with water though Robert. It makes the paint very soft at times and it can flake and scratch very easy. Also it is more acceptable to finger prints. By using water you are diluting the paint. which makes it weaker. Using thinners you are thinning the paint by adding the same base as the paint just thin and with no pigment.....
            • Robert1968
              • Mar 2015
              • 3596
              I use Vallejo most of the time but am a bit CDO (like ODC just in the right order ) When it comes to boats and aircraft.
              I agree with your comment Ian I use Vallejo thinners 2 drops in cup to 10 drops Paint ( l may use a little extra drop on model colour as find that thicker than model air.
              I clean the a / b with my own make on a/b cleaner then rinse brush with water.
              I know I said I dilute with water but at a push only add a drop of boiled water but very rarely.
              I know the fingerprint hassle does my nut in especially even leaving for a couple of days after klear coating.I use gloves when ever I can
              I'm learning all the time and now try to polish and clean my models best I can before final klear/ Matt / dull coats.
