Any one built this model ship?
GuestTags: None
I have built it and it's not a bad kit but if it were me I would go with the academy titanic the quality is that bit better. -
There are so many stands at the show, can anyone suggest names of some sellers likely to sell the Academy Titanic kit?
Thanks.Comment
Well, not finding the Academy 1:400 Titanic at the show, I have bought it. It arrived today Tuesday (24 hours after ordering via ordinary post!). It is the most complex kit I could have ever imagined. It is very highly detailed and has about 20 to 30 times the number of parts of my biggest kit so far. Its overall length is two feet. As a perfectionist slow worker, will I finish it by Christmas? Hopefully. I will start a thread in [COLOR=rgb(40, 50, 78)]Ships Under Construction once I've made some progress.[/COLOR]Comment
I found this if it helps in finding the coloursAttached FilesComment
Thanks. Really helpful.
One thing: the original Titanic and also kits (including the one that I will be making) has lots of lines (ropes) to secure the funnels and other parts. The manual mentions using pulled out softened sprue for these, but on the same page uses the word "Thread". I assume that Sprue and Thread refer to the same rigging material and that "Thread" doesn't refer to, for example, sewing thread.
Is that correct please?Comment
This my academy 1\400 titanic with the sewing thread as the rigging.[ATTACH]296974[/ATTACH]Attached FilesComment
I've just ordered the 1:400 Titanic by Academy.
It looks fantastic. I can't wait to crack open the bix.Comment
Steve - this stuff may be a better more scale like option than cotton thread
Mig Rigging
Haven't used it personally but it looks the part in picturesComment
Ez line is the same stuff and is cheaper.....I’ve used it for biplanes.
It is elasticated so always looks taught, sticks well with CA glue, and survives knocks etc really well as it gives rather than breaks. Similar stuff is made by Uschi. This pages shows it in use....
Fine elastic rigging for aircraft, ships and railroad. 150 feet, 45m, comes in "Standard", "Fine" and "Superfine"
Hope these help...John may stock them as well, worth a check because you can use your membership voucher....
TimComment
Just checked....John stocks the Uschi...
