Hi Folks.
I'm Building a Model of the coaster Ben Ain.
I have fitted the Rudder gear and I am ready to fit my Shiny new bronze
bearing prop shaft. After that I can check out my shiny new Brass Prop.
Now heres the silly question that you all know the answer to
The prop shaft needs to lie flat. So what stop the water flooding in through the shaft past the bearing once it is fixed in place?
The shaft comes with a nut and washer at both ends. Is that to lock to the prop and the coupling?
Sorry if these are basic Questions but I'm new to this bit.
Any help would be appreciated. I think I have most of the other drive and R.C
bits worked out. I will feel a lbigger lemon if I fit the prop shaft and something basic.
Regards
Chris
Regards
Chris
