One for the 'boatguys'
Just had a look at this, the Monogram kit is actually 1:228 scale. Further research shows this kit is 13" long, which would be tiny for an r/c submarine, subs are usually large r/c models.
If you do fancy an r/c submarine make sure you can get the r/c for it. The modern 2.4ghz isn't suitable as it doesn't work when the model is underwater i.e. the radio waves don't travel through water. Older 27mhz and 40mhz radio sets are used by model submariners.
Hope this helps,
Tony -
Just spotted this on the bay of fleas, is this for real ?
a perfect chance to start a R/C Sub build..
https:tongue-out3:/www.ebay.co.uk/it....c100010.m2109
chrisComment
Hope this helps,
Tony
chrisComment
Hi Chris,
Attached is the item from The Subcommitee. The paragraph at the end of R/C Development reads -
The 21st century has seen a shift by manufacturers to 2.4GHz transmissions which have begun to dominate control of model vehicles and aircraft. Unfortunately, this frequency range will not penetrate water and is unsuitable for submarine use.
I still have somewhere a 40mhz set, unfortunately no receiver. I no longer build or sail r/c models, ok with plastic kits nowadays.
TonyComment
Hi Chris,
HI Tony many thanks for that R/C info
Chris
TonyComment
Every day’s a school day!
T
QUOTE]
YEA you are right there Toby im still learning with that new R/C SYSTEM i have just bought as it throws everything i know about R/C on its head an im a bit confused over how to wire this unit up to its ESC but im in no hurry as i havnt finished tigers hull yet so cant fit the eletronics anyway yet an between now an when i am ready i hope to learn a bit more of my problem as ive talked to some guys who are into R/C an so far the answers are 50 /50 so its a case of WAIT till i find out for sure as there is a lot of money 's worth in this R/C SET an i dont want to see it go up in smoke
all best to you
chrisComment
