Help with painting a ship!
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Morning all
    In a few weeks i will building my first ship since the 70's when like most of us i made many Airfix 1 600 ships, in about 20 mins lol
    I have been doing a lot of research but still need advice or to be honest HELP!!!
    One of my biggest concerns is painting, especially the superstructure, boats etc.
    I am thinking of using a AB to do the hull but then brushes to do the superstructure etc, i can see masking the loads of parts on the main deck for example to be a nightmare.
    Not sure if to use lacquer or water based as well??
    Can anybody advise me please
    There will be more ??? Sorry
    Thanks bob
  • boatman
    • Nov 2018
    • 14477
    • christopher
    • NORFOLK UK
    Morning all
    Thanks bob
    Hi Bob m8 well i cant help with the A/B painting as only used a freinds one once an it was not great AN as my ship is a bit big i use rattle cans an then brushes on the decks an on the decking of THE S/S but what scale will be your first ship build be as to me the bigger it is the easyier it is to paint but that just me but if its in a small scale someone like 570 or ralph or richard is the best people to ask as they do small ship models an very well too
    hope this helps you but i'll be lookin in on what you are up too
    chris
    • langy71
      • 1950
      • Chris
      • Nottingham
      Hiya Bob,
      I'd go with an Airbrush for the main base colour and then brush for the superstructure,
      personally I'd use acrylics,
      maybe break the ship down into sub assemblies, paint each and then bring together at the end..(might help with handling whilst painting).
      Chris (Boatman) would have a better idea about painting ships than i would..
      • BattleshipBob
        • 6792
        • Bob
        • Cardiff
        chris
        Thanks Chris
        Was thinking of 1/1 but drive not long enough lol!!!
        A mix of 1 400 and 1 350, have a few old airfix 1 600 as well
        Originally posted by langy71
        Hiya Bob,
        Sound advice, many thanks. Only problem i can see is then glueing the superstructure with paint on it, but thats another issue! But nothing like learning as you go!
        • spanner570
          • 15402
          Bob, can't help with the A.B. question, as I just brush paint and as a result, don't use maskings. To be honest, I don't know how anyone can mask such tiny areas when using an A.B., but I presume folks do.
          What I do know is I found it virtually impossible for me to paint the superstructure successfully (Particularly the small decks) after these are glue in place.
          So I would suggest painting these, and all the small bits separately. If you just use the barest of glue, you won't do any damage to the paint. Then go around the model, touching up. :flushed:
          I use this method right down to my 1/1200 ships.
          I hope this is of some help and good luck with the kits. Although always a long, drawn out build, ships can be a rewarding, and satisfying model when finished - Just stick with it!
          Your Servant,
          Admiral Benbow
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            dear Mr Benbow or Sir, just doffed my tricorn hat (head now very cold :anguished: )
            many thanks for the excellent advice :thumb2:, will try with a AB for the hull, the new booth will not take a 1 350 battleship but managed to fix the old booth so will attempt to roughly join them just for ships
            never really brushed painted a model so off to look for advice but can see the logic for using one, will paint a lot on the sprues boats etc
            thanks again Ron
            sadly a Stug will not float
            • Si Benson
              • 3572
              Just dip the whole thing straight in a pot of Dulux Bob, take it up the end of the garden and photograph through the kitchen window at night....no one will be any the wiser mate :smiling5:
              Honestly wouldn’t know where to start with painting a floater but seeing Ron’s most excellent results with a brush, I’d say he was the chap to listen too
              • stillp
                • 8093
                • Pete
                • Rugby
                I find they usually go away after a couple more flushes.
                • boatman
                  • Nov 2018
                  • 14477
                  • christopher
                  • NORFOLK UK
                  YEA Bob i think 570 advise is is the one for you an basaically its the same as im doin an thats building the bits of S/S seperatly an painting them on the spruses but i hav'nt any spruses as ive got to make all my bits up but its all done in the seperate stage then when you are up to the stage of fitting this all together then do so but dont break the bits off the sprusces untill you are ready to fit the part an then like 570 says just do touch up with a small brush howszat :thumb2: but just see how it goes
                  chris
                  • scottie3158
                    • 14201
                    • Holbeach
                    Sorry mate I can't help i have only ever built one ship and that was the Airfix HMS Fearless when I was about 8. But the advice above sounds good to me.
                    • BattleshipBob
                      • 6792
                      • Bob
                      • Cardiff
                      That might work as they are only greyish lol
                      Never seen a brown ship, lol!!
                      chris
                      Thanks Chris, if it goes shipshaped I'll scuttle it in the lake, do not have a bath lol
                      Thanks Paul, not a problem lol
                      • JR
                        • May 2015
                        • 18273
                        No problem with the spray booth Bob just get a
                        Other makes might be available.
                        To be honest I 'd just do as Admiral Benbow has suggested.
                        Found this as well , thought you might have seen it , but it's good anyway. Like how the guys on top appear to be looking inside.:smiling3:
                        • Defiant911
                          • Feb 2020
                          • 640
                          Hi Bob, I’m no expert and have only made one boat so far but my experience was one of trial & error and despite asking many questions myself about how to go about painting I think it’s a very subjective topic. Everyone has there own preference so probably there isn’t a right or wrong way of doing it. I think the main consideration is lots of planning, e.g, study the instructions
                          In detail many times before you actually start the model. Get an idea of what goes where. You will find some parts of the assembly will be mostly the same colour so you can build that part in one go, air brush in one piece and then adhere at a later stage. Even instructions are not always the best order to do things as they rarely take account of the painting of parts. As a general rule of thumb painting dark colours over light is probably easier-as the other way around usually means a lot
                          More coats of paint to achieve the colour. Sometimes this cannot be avoided though so again it’s about planning the order of things.
                          On my particular boat which was the RMS Queen Mary 1, I sprayed the main hull and also all the decking as I wanted the best possible wood effect but that meant painting the white main body parts afterwards by brush. Again, masking I’m sure is possible if you are willing to spend months doing it which was far more than my own patience would allow. I found in practice glueing onto paint although not ideal practice did work none the less. If you can just sand carefully the surface to be glued, rough it a little and you will be fine.
                          As I say, this was my experience and there are many in this forum far more experienced than myself who
                          May contradict what I have said.
                          Good luck.
                          Ps- what boat/ship are you building?
                          Carl
                            • 18269
                            I use both enamel paints and or acrylic. I spray the subassembies befor attaching them to the hull any glue that has left a mark can be touched in later if needed. I find if left alone and if not swimming in glue, it dries almost perfect. I use liquid cement and a glupper applicator.
                            I have a conversion sheet some place that gives good colour matches with Vallejo acrylics. Failing that Sovereign hobbies colour coats.
                            • BattleshipBob
                              • 6792
                              • Bob
                              • Cardiff
                              [ATTACH alt="1609602840994.png"]409702[/ATTACH] Other makes might be available.
                              [ATTACH=CONFIG]n1140776[/ATTACH]
                              John, thats a top secret picture showing StuG division 999 testing a StuG ship for the invasion of England, also known as 666, but that was after the StuG capised lol. The bloke looking in is Herr Drip with his mate Herr Leak, carrying out tests, trying to identify the fish in the drivers seat, Somehow no crews could be found??
