What ship first. A poll!!
  • BattleshipBob
    • 6802
    • Bob
    • Cardiff
    #46
    Hi Tim, according to the video she was well protected but way overdue a major refit, if you have 40 mins, but on the kettle and have a butchers. I am no expert but he does not blame her just a lucky hit?
      • 18908
      I’ll look out for it, sounds interesting. Regarding protection, she wasn’t up to snuff. Her belt was appreciably thinner than contemporary ships like Prince of Wales. Six to twelve inches in her case, but fifteen inches throughout for PoW, yet she was expected to stand in the same battle line against Bismarck.
      • Defiant911
        • Feb 2020
        • 640
        #48
        If your ordering wood decking hope you have more luck than I did. Only supplier I could find was China with delivery for March so I guess ill have a lot of time to study the ship before building.
        • BattleshipBob
          • 6802
          • Bob
          • Cardiff
          #49
          A wooden deck isba rare thing and not cheap. Be wary of China at the moment because of VAT, i have seen a few French sellers on ebay charging 20%, does anybody know if VAT is now charged on stuff from China???
            • 18908
            Not sure if a wooden deck is strictly necessary is it! They must raise the deck top appreciably, ruining the appearance at the railing edge, and cause all sorts of issues with the deck fittings. Even if they are only one millimetre thick they will add twelve inches to the height of the deck. They are not necessarily the right colour either.
            • boatman
              • Nov 2018
              • 14496
              • christopher
              • NORFOLK UK
              #51
              WELL Tim i was thinkin the same thing an i think if Bob just paints the decks it will look just as good in my opioion but the metal guns barrells would set the model off
              chris
                To use the wood decks properly, you have to remove all the moulded detail - like the 'planking', and make a flat surface. A lot of these AM products are self adhesive. The thickness is about 0.25mm, so in 1/350 about 87mm, or just over 3" - they can be tricky to apply.
                I used the Artwox Model set for the Revell Emden - made a real mess of it & worst of all ruined the surface finish of the wood, defeating the whole object of it! Not one of my best moments!!! Never did finish it! I sourced it from China - it cost about the same as the base model, I remember.
                They can look superb, but take a lot work to fit - not, I think for a beginner!
                  • 18908
                  Can’t help thinking a decal might do the job just as well In the smaller scales Dave. 1/200 and above, yes I can see the point, but not at 1/350 or below.
                  • BattleshipBob
                    • 6802
                    • Bob
                    • Cardiff
                    #54
                    Thanks Tim, perhaps one for the future??
                    chris
                    Will paint the deck, good practice, i hope
                    Sound advice Dave, wondered how they fixed in place! No doubt loads of practice and headache tablets lol
                    • spanner570
                      • 15418
                      #55
                      Sorry for not voting Bob, I missed the bit about being on a 'timer' :upside: KG5 is a good choice. I built the Tamiya one and it's a nice kit.
                      To digress a tad. I agree totally with Tim regarding so called 'Wood decks' I have yet to see one that truly passes muster. On all, the deck fittings sink below the veneer, only a smidgen, but it is still plain to see and leaves minute gaps all around them. The planking is usually way off scale in width and the caulking is far too defined. On most scales, smaller than possibly 1/72, these should be all but invisible on the model. The colour is usually wrong too. On some, the plywood grain the deck is 'printed' on is clearly visible. The outer railing edge is also ruined.
                      The original deck is fine. A far better, and more realistic job can be achieved painting the plastic deck than sticking one on.
                      I realise members will possibly disagree with the above comments, fair enough, that's fine - But my eyes can't tell lies.
                      Your model, your choice.
                      Either way, I'm looking forward to the build.
                      • BattleshipBob
                        • 6802
                        • Bob
                        • Cardiff
                        #56
                        Not a problem Ron. Yet more hard earned advice!!
                        • boatman
                          • Nov 2018
                          • 14496
                          • christopher
                          • NORFOLK UK
                          #57
                          YEA I AGGREE WITH 570 an tim i might be able to get away with it on my tiger but my deck is metal an painted green so i wont bother an save dosh so paint the deck Bob
                          • Defiant911
                            • Feb 2020
                            • 640
                            #58
                            Sounds like I might not be using the wood decking then. It cost £20 but I must admit I had wondered how it might fit it or look around other deck features. Maybe I’ll end up doing a similar airbrush paint job that I did on my previous Queen Mary which worked Fine.
                            as my dad always says, it’s only money, you can’t take it with you..
                              • 18908
                              The deck on your QM looked spot on to me. Why spend money on something that will still need work and may not look so good?
                              • Defiant911
                                • Feb 2020
                                • 640
                                #60
                                I guess I didn’t do my due diligence this time.
                                sometimes the moment of seeing something I have not tried before and the idea that it could look much more realistic blinds me. You live and you learn I guess.
